Rear window won't go down...
farmerjon
Senior Member
I know this has been asked before, and yes, I did search... My rear window won't go down now, it is stuck all the way up. It doesn't make any noise (that I can hear)...It also doesn't move at all.
What I've tried:
  • Locking/unlocking the window lock
  • using the rear window key
Is there a fuse I can check? Is my motor bad? What's going on?
Thanks!
Solved it... using another thread on here...
My window wouldn't go down, so I turned on the rear defroster and the rear wiper, and it works!! :D
I'll leave this up to remind people as another solution to try... Seems to be pretty common
So what's next?
I rolled mine all the way down, now it won't go back up!
I tried all the tricks listed and got nothing.
It did this a few weeks ago and I tried the wiper thing and got it to go up but now I'm thinking I got trouble.
Would it be cheaper to by a whole new cargo door or get it fixed at the dealers?
If I had these problems, i would just remove the trim, and the metal cover, and all the wires and clean/lube/tighten every single part, paying particular attention to all wiring harness connections. Every terminal in every connector.
For myself, that solves the majority of the these types of problems.
I don't know anything about these electrical gremlins with turning on other switches etc...just a casual opinion.
I did tear into it and play with a few of the connections with no luck.
Is there a quick test I can do?
I can't seem to find anything on it in my Chilton manual.
If you are handy with a test light/probe you could have someone press the switch (or jumper wire the switch yourself if you don't have a helper) and test the connections. Check your lead harness, and check for 12V power. I don't have a wiring diagram, that would be quite helpful here. Check the links in the sticky for the FSM.
OK one more question, will the rear window defrost be de-activated when the window is down?
I can't get it to turn on, and I checked the fuses and the look OK.
