Rear wiper issue
Ace96
Have a little different rear wiper issue compared to what I could find in the search. Our 2016 4runner the wiper will only work on intermittent setting. Flip to on and nothing happens. Spray feature does not work either. I am hoping it’s the stalk but wanted to see if there is anything else I should check first?
Have a little different rear wiper issue compared to what I could find in the search. Our 2016 4runner the wiper will only work on intermittent setting. Flip to on and stays in place. Spray feature does not work either. I am hoping it’s the stalk but wanted to see if there is anything else I should check first?
did you check the washer fluid level?
Update. Changed fuses with no success. Changed out wiper stalk and no change. Wipers work on intermediate. Sprayer does not work. Wiper fluid is full. To sum up rear wiper works on intermediate. Does not work when turned to on nor does the sprayer work. Next steps???
You could try to disconnect the battery for awhile to reset the hatch module. You may have to reset the window travel limits (push and hold for a few seconds when it's all the way down AND all the way up).
I had the battery disconnected when I changed out the stalk. I did hold the button down or up. Thanks.
seltzernator
