Recommended body lift & tires? Help please
THend13
I've been looking at tires and a body lift for you 06. It's all stock. I dont want to lift too high. I was looking at toytec body lifts and fierce tires attitude m/t 265/70r 17. Can I go bigger on the tires? If so, how big of a body lift will I need?
I would love any suggestions as to different tires or body lift.
Thank you
I have an 06 sport totally stock and just put some General Grabber At2's on them, look fantastic. Snowflake symbol too so hopefully good for snow up in the N East where im at.
Get at least a 3 inch body lift. That's what you're going to need.
Thank you
Do you have or do you plan on a suspension lift? I would go this route before the body lift. You can do a small suspension level or lift kit and have enough room for the 265/70/17's. With just a 1-2" spacer on the front to level it, 265/70's would fit with little to no trimming.
If you want bigger, you can look into a 275/70/17 (I would suggest a 3" front, 2" rear lift). The only downside is not many tire options in this size.
Even bigger is the 285/70/17. For this I would suggest a 3" front, 2" rear suspension lift and a minimum of 1" body lift. For this you would need wheel spacers to clear the UCA and some trimming.
Regardless of tire size, I would definitely suggest a suspension lift over a body lift to get things started.
