Red gel for off road lights
amatuerfisher
Hey all,
I currently have some of the cheap LED light pods mounted on my roof rack. When fishing, it would be nice to tint them red, as not to kill everyone's night vision.
Has anyone found any sticky red film, similar to a stage lighting gel, that I can adhere to the lens covers when needed? It would only be for lower speed applications (<45mph).
My thanks for any ideas/suggestions!
Thanks for the suggestion [MENTION=147436]feusaf[/MENTION] - but note I meant eyes adjusting to low light, not actual NVG usage. I'll check that Roscolux stuff out!
I didn't mean NVGs either :)
Blue or free is a better light color for night vision period. Red changes hues and makes depth perception harder.
My apologies. Re-reading your earlier comment clears that up. I'll definitely look into the other colors as well.
The face of your lights comes off and it's a clear flat piece of lexan there, I put amber 3M wrap on a set I have and they've held up great.
You could do something like this: Rosco Roscolux #120: Red Diffusion - T12 24" Sleeve (Rosco Roscolux RS #120 T1224)
But I'd suggest going with blue or green, it's more natural and may not wash out. I've driven military vehicles on NVGs with green overt lighting and can see pretty good without the NVGs.
I use this Roscolux brand for my photography lighting... its really high quality stuff, good optical performance and excellent even with hot lights.
I got a couple of those sample packets and made red filters for some flashlights as they are the perfect size... might be a good/cheap way of going about it.
How hot is hot? I was thinking of inserting an amber or yellow gel sheet inside a projector light assembly instead of the usual transparent film or paint on the exterior surface of the lens (which gets torn up or chipped over time by debris) but am unsure of the melting point of those sheets
I'll definitely try out the 3m wrap!
For the legality - it will only be on when off road on the beach, so shouldn't be an issue.
I mean hopefully you don't run into an issue, but legally you cannot have any red or blue forward facing lights. Even if you aren't operating them on paved roads, if an officer does see them they could technically pull you over and issue a citation.
And if operating on a beach couldn't local beach patrol as well, because it is viewed as impersonation?
Pretty damn hot... I used them on studio lights which probably generate way more heat than car lighting.
https://www.rosco.com/specsheets/filters/Rosco_ROSCOLUX.pdf
You can operate them at about 320F
Melting point is 428F
Very good point... Blue/Red or even white alternating flashers of any kind are just asking for trouble.
That's also a good point. Someone suggested clip on filters. I'll try the 3m wraps on the rear lights and just put the clip on front on when parked. I've seen others out there with red and green lights, and the NPS rangers didn't seem to have any issues. Don't need to tempt fate on the roads!
