Reduce liftgate travel?
any updates?
Hey All. New member and owner of a 2016 T4R. I'm having the same issue and was wondering if there have been any updates on a solution especially curious if there are shorter struts that can be installed? Thanks!
They say a picture is worth a thousand words...
Not exactly a place I could put some foam. Plus anything that contacts the body is eventually going to scratch the paint if the rig moves at all (which it will when loading/unloading things) with the liftgate open. The metal strip on the bottom of the garage door is already leaving a mark on a couple of the 4RUNNNER letters.
I don't have enough room in front of the rig to pull it in far enough for the liftgate to totally clear. And it's not practical to have to back in every time I want to load/unload something from the back.
To me it looks like shorter struts is the best option. Guess I'll have to do some research.
See post 3 in this thread http://www.toyota-4runner.org/5th-gen-t4rs/209558-building-driving-adventuring-mtn4rnr.html
Our garage door hangs below the opening. So a few years back when the thin rubber piece on the bottom of the door froze to the driveway after an ice storm and ripped to pieces when I opened the door; I replaced it with a strip cut from a rubber stall mat from TSC. The 4Runner lift gate bumps softly into it.
This might be an easy fix. It will not look great..but since you will only use it in your garage or a very low parking garage, who cares. Get a long bungee cord or light nylon robe with a couple of hooks. Hook one end to a cargo loop on the floor of the 4runner, the other end somewhere towards the bottom of the hatch door. Adjust the rope or buy the appropriate size bungee to keep the door from opening too high while in your garage. When however, you need to have the door wide open, don't use the rope. Simple.
I suggest you place the rope hook inside one of the handholds in the bottom of the door while you are adjusting for the proper length. You can then place another "cargo loop" type attachment hardware within that handhold, that way it will not interfere with opening and closing of the hatch. When you need the rope, just attach it prior to allowing the door from going all the way up. Be safe.
I had a similar problem with my garage and where I parked it. I took some parachute cord and some cheap aluminum carabiners to make a limiter. I connect it to the cargo loop and then to the lift gate strap.
Not super cool, but it worked.
This is what I did too, but I used good carabiners just to have in the car. If you have the cargo net, run the cord behind the net and it will fall back into the vehicle when you close the door. This has been great to use especially since getting the truck back from the body shop... After smashing the lift gate on the garage door....... :nod:
So thanks to all those who replied and those who uploaded pics! Just placed an order for a couple Nite Ize Camjam XT's and should have them in a couple days. Still not giving up on finding shorter struts, but this looks like a great alternative for the time being.
Great minds! my cord is green.
I will tell you that from having the paracord and carabiners on my truck, you're NOT going to enjoy having shorter struts. It's a real pain in the ass getting under the lift gate multiple times when it's pulled down like that. It's great for what it is but when I'm not in the garage, I take that top clip off.
I think the ultimate solution would be some way to index the door opening so it could be set at will like with an electric motor etc.
Pictures are worth.. Well This one was worth $3200. I had foam between the door and garage door but forgot the lift gate was open....
i used to leave my carabiner tether attached full time, but noticed that the weather stripping was torn where the carabiner lies. Mine has the 3rd row, so perhaps that allows for more contact area, but just be careful of the contact.
I run the paracord behind the cargo net so when I close the door, the carabiner falls down behind the net and inside the truck. I was concerned about that hitting the trim or getting smashed between the door and body too but the tension from the net pulls it in. You could also attach a bungie to something then the paracord too to get it to fall inside the cargo area I imagine.
Forgot to mention, the second pic shows the carabiner that I usually attach to the door tether. I hook it to the seat belt shown when not in the garage. The other side is attached to my lower PS cargo anchor point. The length of the tether allows the carabiner to slide between the raised floor and the door, causing damage. I suspect that for those without the raised floor, don't have this sandwiching problem.
Ah. Mine is the regular 2 row no cargo tray floor and the wheel wells are different too.
Looking at the photo of your garage door and rear hatch, I'd say you have at least 3 options:
1. The carabiner/rope rig that others have mentioned.
2. Throw a towel on your rear hatch where the hatch hits the garage door/garage door frame. It looks like it hits right on the Toyota emblem. Mine hits in the exact same spot. I used an old garage towel for years to keep my hatch from rubbing on the garage door.
3. Foam on the garage door and/or garage door frame. I recently did the foam option because I got tired of the towel trick. I had to adjust my garage door so it wouldn't open as far. It now stops about 1" below the garage door frame. Then I put foam on the bottom edge of the door. I also put a little foam in other places for good measure. Foam was secured with zip-ties (drilled some holes in the bottom edge of the door and put the zip-ties through the holes). Like this:
a>~original
All 3 options will work without having to buy shorter struts, which sounds expensive and could hurt resale value (most folks don't want to lower their 4Runners... they want them lifted!).
a>~original
I think OP was talking about shorter struts on the lift gate, not lowering the overall truck. :)
I tried the foam too. It works great for the banging of the lift gate however as my picture will attest.. There are additional downfalls of having the gate open that high in the garage....
I have an update here. I did not want to put foam on my house, and I didn't want to rely on a paracord travel limiter. I am also 6'3 and did not want the hatch too low. I worked with Lift Supports Depot https://www.liftsupportsdepot.com to find a lift strut that was slightly shorter.
I have a stock height 2016 SR5 with a 1 inch front lift and 265/70/16 Falken Wildpeak AT3W tires. I have a 7 foot garage door.
If you call or email Lift Supports Depot, you can get this strut with the proper ends for our 4Runners. https://www.liftsupportsdepot.com/
You want their StrongArm #4584 lift strut. It is right at 22 inches fully extended.
It is slightly more effort to close the rear hatch, and I have to just slightly duck to not hit my head on the edge of the hatch, but it clears my garage without issue. Once I'm past the edge of the hatch, I have headroom underneath it.
IMG_4696_zpsq0x5k8y8.jpg~original
IMG_4697_zpsuquqqqdw.jpg~original
peacefulpiranha
