Remove Web Apps from Entune?
SirBarton
Anybody know how to remove the web apps (pandora, slacker, etc) from Entune? I only ever use Satellite, CD and Bluetooth.
I'd like to be able to use the mode button on the steering wheel to cycle through only those 3 options, but I usually end up reaching for the touch screen because it's quicker than going through so many different modes.
Can't seem to figure out how to do it. I'm thinking maybe I need to delete the app from my phone and do a system reset in the car but before I lose all my presets I figured I should ask...
I don't have an answer as I don't use the Toyota app. But this does bring up the question if the so can be disassembled and modified? Maybe to load other functions not currently promoted like Google Maps?? Hmmmmmmm.... Makes me wonder
I'm assuming you would need a third party software/firmware. Those apps are on there for a reason... Marketing.
Think of it like this: your standard smartphone comes loaded with an operating system. On some phones you can load different software but this requires you to make changes to the system. Some allow it and some don't. Example: Nexus phone and Apple phones, open vs proprietary source.
Entune is not open source so there is no way to change the code unless Toyota released the source code. And if they did, you would need someone to change that code and allow you to do so. Which probably wouldn't happen because there is not enough interest in it.
Not trying to ramble, just trying to give you a better picture. Hope this helps.
It's pretty obvious why they are there. I just want to remove them from the mode buttons loop of presets. I'm going to try a system reset and delete entune account.
Doesnt matter what you do they cannot be deleted. Only way to remove them is to replace the hardware with mother option allowing you full control over the deck. That is what the previous response was alluding to. That you cannot change it onl someone with access to the source code could and toyota hasn't released it nor will they allow it. So in turn unless you replace the unit your stuck with it.
I'd assume a factory reset should work since the Iheart/Pandora icons did not show up on mine until I activated & sync'd the Entune Plus app.
This is what I did to mine to get it to stop cycling through those features. Deleted my entire account and performed a factory reset.
Sent from my SM-G920V using Tapatalk
Well I'm glad you were wrong. As noted in other posts, if you do a factory reset and delete Entune from your phone and your web account they go away. If I would have realized this in the beginning, I would never have enabled Entune or put the app on my phone.
So happy to have them gone. Now I just need to reprogram my presets and we're all set.
Well I am taken back. Did not think for a minute that they would allow those to even come off of the screen. Interesting. The bigest issue with Proprietary items is that they are usually closed and unable to change things around an exception would be the apple ios. I find it appalling at how far we have come with integration with our mobile devices yet can't have a car enetertainment, mobile computer, navigation, center with a 1/4 of the capability and less than that in the term of immersion into the interface. I am very interested to see what the future holds when companies like apple get more into the integration with manufacturers. A point that boggles my mind is why Korean vehicle manufacturers do not leverage the technology out of their country and other manufacturers to put something onto the market that gives them a special niche and drive at least one area of it.
It is shocking how few options you have, even in expensive luxury cars. The systems are just way too locked down. I'm not sure if it's because of federal regulations or concerns about hacking the software or what, but it is ridiculous given what kind of customization we can have on our smart phones and tablets.
And judging by the lag in the system, there can't be much of a processor in the head unit. It's slow as molasses.
Worked for me too! The Entune apps are over hyped.
Before I hit the reset, I took a picture of my radio preset to help set them faster. Didn't have much programmed into the navigation, so setting my home address was all I needed to add back.
How did you guys "reset" the radio? Is it a sequence of physical buttons on the radio that need to be pressed, or is it an option somewhere on the settings menu?
I searched the forum, and Googled some sort of tutorial on this, but nothing. I've already deleted my Entune Apps account, and removed the app from my phone. Just missing on how to reset the radio.
Thanks in advance!
It's crazy to me that in 2017 we can just have a screen to mirror our phones? Our phones these days do everything we need. The closet they have is Android and Apple auto even those are extremely locked down.
Sent from my SAMSUNG-SM-G890A using Tapatalk
Thanks in advance!
I second the question... how do you "reset" the radio? I too have searched and Googled, but came up short.
Thanks everyone!
Entune Factory Reset process
Thanks everyone!
I dug around on the net and coalesced the needed info. I too used the Entune app suite for about 3 days and determined they had zero added value, and wanted them gone. I found this thread which gave me the confidence that an end-user solution existed.
Here's the steps.
1) turn on ignition, but don't start the car.
2) press and *hold* the APPS button on the radio while performing step 3 below.
3) cycle the head lights 3 times (turn on then off the headlights 3 times)
- this activates a hidden service screen on the display, you can release the APPS button
4) press and hold the "INIT" button on the display until a dialog box appears with the text "Personalized data is initialized. OK? [YES] [NO]"
5) select YES, and your radio returns to the factory settings
here's a video of the process:
entune-factory-reset
This process will blitz the added Entune apps (like Pandora, iHeartRadio, Yelp, etc.), and also removes your saved contacts, nav points, radio presets. Restoring my presets and contacts took me about 5 minutes. Well worth the time to get those Entune apps out of there. I have not found any ill effect of this process, the Nav system, XM satellite trial subscription, bluetooth, etc works as expected. But your mileage may vary I suppose.
Remember, you can still listen on your car's sound system to any audio app on your smart phone like Pandora, just utilize the Bluetooth Audio function of your Toyota's sound system and setup your smart phone to beam its audio to bluetooth. Your smart phone is a way better interface anyhow.
Here's the steps.
This worked like a charm!!! Performed exactly what I wanted and as you stated. Thanks a million!!! :thanks::cheers::thumb:
Bumping this old thread to ask if anyone has done this on a 2019. I'd assume it still works. I want to get rid of the stupid slacker and pandora apps that I never use.
Here's the steps.
I just did this on my 2019, as things have gone wonky with my iPhone 11 - the iPhone X I originally paired worked perfectly. So the procedure itself works...we'll see if it actually solves the disconnect problems. Here's hoping...
AndiGarage
