Removing 3rd gen driver door/front fender
Door is easy. Remove the kick panel so you can unplug the door wiring. Then disconnect the keeper that prevents the door from opening too far then remove the door hinge bolts starting with the bottom.
Fender has 2 bolts on the bottom in front of the door, one along the edge of the front door opening, 5 or so along the fender in the engine compartment, and then one below the headlights. You will also have to undo the little filler panel under the headlights.
Both are pretty easy. Definitely helps to have someone help hold the door.
AndiGarage
