Removing front skid
Quetico
Can anyone tell me the steps involved with removing the front skid? Also, what is the approx weight of this thing?
I did my first off roading trail last weekend, and the front skid took a few bumps. I want to touch up the paint and try to bend the screen back into shape.
Should I touch up the paint with Rustoleum, or is there something better to use?
The bolts pretty easy to spot that hold the skid on. Just loosen them and drop the skid. Not sure why you would want to paint the scratches it is a skid plate not a dinner plate and does not need to look clean to function. I would check for major damage and then just leave it alone.
I find it so much easier to take off and on the front skid plate if you first remove that small blast piece in front of it. 5 10mm bolts and that plastic tab in the middle. I still haven't figured out how to remove that tab with finesse, normally I just tug hard enough until it comes out! Be gentle with these bolts, I snapped one already with not a lot of force.
Front skid plate is 4 12mm bolts.
Well, I want to drop it to check for damage and bend the screen back into position. Figured once I have it down, I may as well touch up the paint to keep ahead of rust.
Good idea. Doesn't weigh as much as the one on my 3rd gen. I spray the skid plate on my 3rd gen every year to keep it from rusting. I use Duplicolor Semi Gloss/Satin black paint.
I managed to get the skid down tonight. Pretty straight forward, except for that p-i-t-a plastic clip between the skid and the plastic piece in front; that might be broken, we'll see if it goes back together tomorrow. There must be a better way to get that out, but I didn't find it.
The other thing I don't get is the flimsy metal mesh in the skid. What's up with that? All in all I was able to bang it back into place pretty well.
They just don't make them like they used to!
tyler_ross
