Removing the front bumper?
Here is how to do it.
[/URL]~original[/IMG]
Haha that's definitely one way
Got it removed....no moose meat involved. Decided to actually crawl under and take a look. I needed some posts anyway so I can post a legit question soooo....thanks guys lol
its 4 bolts exactly. They are on the interior of the bumper, located about an inch closer to center from the turn signals. one up high on the bumper, one lower. lie under the truck and check it out. they are pretty visible. Im pretty sure its a 12mm. I had to take mine off a few weeks back. You will need a deep socket or open ended wrench.
Put those 15 back and take off the right ones. Are you separating the lower valence from the bumper? that accounts for 8 bolts. plus a 4 pressure tabs for the turn signals.
Hi 1st timer. I took off the 2 bolts, but bumper doesn't want to come loose. I have 98 sr5 limited, is there more than the original 4 bolts because of the molding on bumper?
It tales SIX bolts, not four. The four in the center and there are two more just inside the fenderwall in each wheel well. They point forward and are kind of recessed into a hole.
Mike Sargent
