Repair suggestions - cracked center armrest
pj2006
Continuing with the quality decline of Toyota products, my 2016 SR5 now has a cracked center armrest. The crack is about 1 inch. Any good repair kits or methods or should I just spend the $300-$400 to replace?
Can you remove it and have it upholstered?
1. REMOVE CONSOLE COMPARTMENT DOOR SUB-ASSEMBLY
(a) Remove the 6 screws and console compartment door.
2. REMOVE CONSOLE COMPARTMENT DOOR HINGE SUB-ASSEMBLY
(a) Remove the 2 screws and console compartment door lock.
(b) Remove the 4 screws.
(c) Using a screwdriver, detach the 6 claws and remove the console compartment inner door.
HINT:
Tape the screwdriver tip before use.
(d) Remove the 4 screws and console compartment door hinge.
You should be able to find a good used one on Ebay for far less than a new one. Plus, many dealers sell new ones for less on-line.
Jhunt
