Replace the radiator??
apinion33
I just picked up a 97 this past weekend. It has quite a bit of rust under the front bumper area. I changed the oil today and while I was down there I noticed the bottom of the radiator was pretty rusty looking and pretty brittle to the touch. I am planning on flushing the coolant but do u thing I should just replace the whole dam thing. And if I do should I flush before I change the radiator just to make sure no old fluid from the engine goes I to the knew one? Trying to bring this baby back to life she needs lots of love. Came from Hawaii to Cali so has a few busted rusty parts.
Yes - replace radiator. It contains trans cooler which is known to fail over time, mixing coolant with trans fluid and causing catastrophic trans failure (search pink milkshake). Best to replace it....
Cool thanks. Are those the exact parts I want. Do they come complete ready to install?
IIRC they do require some extra hose. I would also suggest, especially being in California, that you look into a larger cooler, the B&M 70264 at the very least and perhaps one even larger.
How about the coolant fluid. Toyota red or pink work with this?
Most will share this opinion, go with Toyota red 50/50 with distilled water. Some will say any EG antifreeze, but that Toyota stuff is excellent and keeps the insides or cooling systems pristine. In a hot climate you may get away with 45 antifreeze and 55 water to keep engine temps down slightly, but it shouldn't affect it either way, 50/50 is the golden number.
