Replacement spark plug wire guides/clips?
ki1022
Does anyone know where I can get the clips that guide the spark plug wires and attach to the timing belt cover? Both mine are broken. I tried google searching for a part number but couldn't come up with anything.
TOYOTA | Japan Parts EU
Plug in VIN then look under: engine/ignition coil spark plug
There are a bunch of clips, but I think what you are after are 19944-62010 (they are $2.99ea at Camelback)
Thanks for the part number.
Just started my timing belt change and I'm already breaking things. The Passenger side clip broke just by looking at it, the middle one is good and the driver side snapped after a little nudging.
They are included with a new spark plug set from Toyota also. all the clips and dividers along the plug wires are.
Did not know that. Too bad I just ordered a new Denso set before this happened.
I'm assuming #19037-62010 is the right number for the OEM wire set. Looks like I can get it on Amazon for $45 bucks. Crap, maybe I should try to cancel my Denso order.
freddygino
