Has anyone replaced the coolant in a 2003 V-6 themselves? My 2003 4Runner just turned over 30k so I bought the premixed pink Toyota coolant (yeah, the stuff with the "unobtanium" in it!) and tried to replace the coolant this weekend. According to the owner's manual the coolant capacity of the V-6 is 9.8 quarts, or slightly over 2 gallons (U.S.). I removed the sheetmetal guard under the radiator and opened the radiator drain, but after an hour+ only a little more than a gallon had drained out. I filled the radiator with a gallon of distilled water and ran the engine until it reached the normal temp range, then opened the drain again. Same thing...a little over a gallon drained out. I did this twice more, all with the same results. Each time I ran the engine up to the normal operating temp so the thermostat should have opened; should I have just removed the thermostat for the coolant replacement?
Obviously there must be one or more additional drains that I couldn't locate; what's the secret to draining all the old coolant out? I've owned and worked on Toyotas since 1981 and I never encountered this problem before. Help!!
