replacing front axles - which seals should I replace?
moodle
I'm putting Cardone Select 66-5235HD Constant Velocity Drive Axles on my 4th G 4Runner, and I've read a few threads that discuss replacing seals at the same time.
But they mention different part numbers than my dealer's system shows - their parts department is not the best so I don't trust them. They also first ordered seals for the rear, and not for the front like I had asked for.
The part numbers mentioned in previous threads are:
90311-47012
90311-47013 my dealer says this part # is now 90311-47027
Is this the same part? And are these two seals the correct ones to replace?
Thanks in advance for your advice.
Matt
I usually input my vin# on
https://www.toyotapartsdeal.com/
I have ordered lots of parts for my toyota's using that method and never received an incorrect part for my model/trim. A side note is toyotapartsdeal usually lists old/new/replaced part numbers as reference if applicable.
That might clear up some of your confusion with all the part numbers floating around.
044runner4
