Hi folks, does anyone have a DIY or some basic steps on how to replace it. I know I have to pull the Alternator and also the compressor - any photos out there and how long of a job? Thanks
I just replaced the whole tensioner assembly. Yep I tried to remove the pulley and did not realize that the bolt was left hand threaded, ugh!
There are 5 bolts to the tensioner assembly. The access is really limited. I took the bolts off of the alternator, and removed the wiring harness bolts connected to the alternator.
I could then pull the alternator out towards the radiator and tie it up towards the battery. Then you remove the 4 compressor bolts and the ac line hanger off of the front of the engine. These 4 bolts are tough to get to. I used my 1/4 drive on these with an cheater bar from my 3/8 drive with a large socket to go over the ratchet handle. I also use a wrench to get to one of the 4 bolts. PIA!!
Once the ac is freed up you can push and pull the compressor to get at the lowe of the tensioner bolts. Took me a good few hours and some skin off of my hands.
Get your replacement out, so you can see where the bolts are. Not much room to see the actual bolts.
Good luck! Sorry no pics.
i removed the alternator completely and took out all four bolts for the ac compressor, but i didnt disconnect the ac lines, you can move it enough to get to the bolts for the tensioner. If your doing the tensioner pulley i suggest replacing the the idler pulleys as well. Be sure to torque the pulleys also.
Oh yeah. got to get the alt out of the way and the ac compressor unbolted and moved around 2 to 3 inches to gain access.
Why are you removing the tensioner and not just unbolting the tensioner pulley (left hand threads)?
How difficult was it to move the tensioner?
Were the pulleys the same size?
Was it working before?
Did you have the belt threaded properly?
When I was done it was really difficult to get the belt on. I had to rotate the tensioner really far. I was putting on a new belt, so it should be tight.
Wow. There were 2 wiring harness bolts that freed the alt. I think I pushed it down off the bolt mounts then pivoted it towards the radiator
But if the tensioner and belt worked before it should be ok once u replaced the pulley. Does the tensioner spring seem pretty strong when pivoting. I would double chk the belt threading. Getting the ax compressor of is a pia too.
