Replacing Valve Cover Gaskets - A True Write Up - **PICTURES**
Awesome write up! Quick question, so you didn't have to bend the tabs for the
spark plug seals? I'm assuming it's because you froze the seals? Thanks.
I just didn't have to. I don't know why people say they have to...I don't think it has to do anything with the frozen seals
I'm assuming people do it so they can use the 34mm socket as a seal driver and they need the tabs out of the way. When I do this job, I'm going to try it your way and if all else fails just bend the tabs. Thanks.
Nice write-up.
You did go a little overboard on the FIPG though with the big long bead you put over the cam body and half moon. You only needed to put it in the 4 corners where the raised cam body makes a 90 degree corner with the flat surface of the head and then over the 4 junctures of the half moons. So, 8 small beads of FIPG per head.
I don't know if you knew about the video [MENTION=102606]infamousRNR[/MENTION] and I did on this repair but here it is in case you or somebody else finding this thread would like to check it out.
Nice write-up.
Yes, I know I went overboard, the pictures in the manual showed the exact locations it needed it, but I decided I wanted more than that . . I'd rather have a little too much than not enough.
Yes, I saw your video on TW and on here, but I got impatient with how long it was and decided to make a picture writeup for those that don't have the patience to watch the video :)
Yeah, our videos are long but I decided when I started doing these videos with [MENTION=102606]infamousRNR[/MENTION] that I'd rather give people too much information than not enough. I figure if people want to know how to do the job, they'll sit through a long video if it means they will have all the information they'll need to be successful doing it. And plus, there's always that handy fast forward button if somebody wants to skip something or is tired of hearing me talk.
I've personally always preferred a good video to a good write-up, because a write-up, no matter how well it was done, just can't show the level of detail a video can. It's basically comparing 2 dimensional with 3 dimensional and there's just no comparison. I use write-ups as one of my resources to research jobs Sean and I are going to do, so they are a great tool and I'm grateful to the people who took the time to put them together.
I guess you'll really hate our next videos coming out because they're even longer than the valve cover gasket repair. We've got two axle seal videos coming out soon and they're going to be around an hour each. Oh the horror!
Bookmarked for later, thanks for the write-up! The video will also be useful as well, just venturing into 4runners with an 02 SR5.
What is the torque setting for the cam plug cap? 12 ft-lb?
Yes, 12 ft-lbf or 144 in-lbf
great writeup, I just did this a few weeks ago man it was a PITA esp with those damn fuel rails but got it done in only 7 hours!
It's hard to work on the rig, and then stop and document stuff.
Work...stop, and document...continue work...stop and document...etc.
Thank you for taking the time out and doing this write up!
Nice stuff. You should create a build or journal thread that links all the helpful threads you personally created.
Thank you, have all parts here waiting to do this, Timmy the tool man has a good video on it as well and it's great to have a step by step with pics while you're doing it. Taking a break while swapping steering racks as I type this haha
OK question: Camelback has the gaskets listed as "left" and "right", I assume these are the corect ones to order? Also, total for order is $155 (just enough for free shipping!), sound like a good deal or did someone find a better one?
Thank you for the write-up. More info and opinions make sure this forum is constantly evolving.
How's the bead on that FIPG!? Whoowee. I'd hate for that to set up and then break off inside and lodge into an oil gallery.
Killer write up! I had to do this job twice a couple summers back because I screwed up the first time and I didn't replace the camshaft plugs (just reused).
I will also add to the voices of caution on your gratuitous use of FIPG though. I definitely read the same things about it being bad to apply too much of that stuff, so I'd err on the side of caution and just go with the recommended application amounts and call it good.
Thanks!
One last noob question. Being the half moons are aluminum do you really have to replace them or would resealing with FIPG suffice?
As OP mentioned, you can reuse these. I did, and I'd recommend against it only because FIPG is a huge pain in the ass to clean off completely. It really does add a lot of time to the job, and if you've never done this on your truck you're going to be cleaning up a lot of other things along the way and you'll appreciate spending the few extra bucks on the half moons.
2001ATL
