Replacing XREAS w/5100... new bushing part #'s?
PwAg
Replacing XREAS w/5100... enough to just replace sway, endlink, & strut bushings?
Replacing XREAS with Bilstein 5100 on 2008 V6 4WD Sport. Will use stock coils, set to stock 0" height on Bilstein body.
While doing swap, would like to change out any relevant bushings while everything is out and I'm under the truck.
Tried searching forum, no definitive answer for OEM stock part numbers. Thinking of replacing the following:
1. Top strut - body bushings
2. Sway Bar bushings
3. Endlinks
Any other recommended swaps? I have found the Prothane part #'s, not sure I'll go that route at this point.
Are these all the same over each variant of the 4th gen? Tx
3. Endlinks
I just ordered these end links and these bushing kits to install at the same time as my lift. I got my coil springs from a 2012 FJ that a dealer swapped out before it sold and they through in all the bushings for the strut assembly. Toytec sells these bushings.
