Reset ECU Yes or No?
Aquabear
Hey guys,
Again thanks for all the info here, in the wise words of Bill N Ted you're all EXCELLENT:guitar2:.
As I posted, did a bunch of work on my 4Runner- AFE CAI, new NGK iridium plugs and now new Amsoil fluid in Front and Rear diff and in the Transfer Case.
Per many write ups I did remove the neg battery cable when doing the plugs n CAI to reset the ecu (correct terminology?) BUT I did not unplug it when doing the Front/Rear Diff and Transfer case to reset the ecu. I also added Inject cleaner in the gas tank.
I know my trucks reading on mileage went down to 15/16 mpg HORRIBLE; but today I saw a high of 16.9 but still thats low in comparison to what she was prior to all the changes at minimum 17mpg.
Others posted the computers not accurate- ok but to drop???
Should I unplug the neg cable to reset the ecu OR just let time go by and it will settle itself?
Thanks for your help.
Hey guys,
Try this - It worked for me. I got a drop to 15-16 after pulling a trailer for 300 Mi. I reset things after fluid change and tune and now get 20+ around town and ~23 on hwy with stock duncrap tires (got to get rid of these).
http://www.toyota-4runner.org/557334-post5.html
If you do it this way you won't have to reset the PWR windows and audio memory (as opposed to disconnecting the batt cable).
No need to reset the ECU for the fluid changes and injector cleaner. My guess why VaWoodpecker saw a change was because he hadn't reset his on-board for ages and resetting the ECU did that and only that. No way his resetting the ECU had anything else to do with "improving" fuel milegae by 5-7 MPG.
I just did the VAWoodPecker and when I started the truck again it didnt even reset the onboard mileage calculator?
Did this do anything?
I did not reset due to fluid changes, that was an aside as to when I reset it. I reset it due to the mileage drop from towing. I changed out all of the fluids after the tow and then reset things. I had the full fluid swap (fdiff, xfer, rdiff, & 18 qt tranny flush) on my list of things to do to the 4r after I got her back in March for a fresh start, and I decided to do it then at 25K. I would have reset the ECU then anyway even without the fluid change. I do not think fluid change really would be cause to reset things. AN ECU reset is really probably just needed if you do a tune up or see a drop in mileage after changing driving patterns. For me it was the change in driving patterns hauling a trailer.
No, it had not been ages since I reset :confused:
It was not the first time I have done this with success.
Resetting the ECU did increase my mileage, it relates to driving patters and how the transmission and engine learn driving habits (hauling a trailer for hundreds of miles can establish a new pattern). If you start getting crappy mileage - try it.
I think you could also maybe get a few MPG increase on a long trip if you reset before you hit a long stretch of hwy.
workingwheelswnc
