Is this reset the same for a 2006?
It should be...BUT the procedure is in your 2006 owner's manual on page 153.
If you don't have the manual here's a link to a PDF version of it.
https://assets.sia.toyota.com/publications/en/om-s/OM35852U/pdf/OM35852U_edited.pdf
Also here's a copy and paste of the procedure.
(h) Engine Oil Replacement Reminder
Light (for vehicles sold in U.S.A.)
This light acts as a reminder to replace
the engine oil.
This light will come on when the ignition
key is turned to “ON” and will go off after
about a few seconds.
When you drive for about 7200 km (4500
miles) after the engine oil replacement,
this light illuminates for about 3 seconds
and then flashes for about 12 seconds
with the ignition key turned to the “ON”
position. If you continue driving without
the engine oil replacement, and if the driving range exceeds 8000 km (5000 miles),
the light will come on after the ignition
key is turned to the “ON” position. The
light will remain on thereafter.
If the light is flashing, we recommend that
you replace the engine oil at an early
opportunity depending on the driving and
road condition. If the light comes on, replace it as soon as possible.
You need to reset the light after the engine oil replacement. Reset the light by
following the procedure below:
1. Turn the ignition key to the “ACC” or
“LOCK” position with the odometer
reading shown. (For details, see
“Odometer and two trip meters” on
page 146 in this Section.)
2. Turn the ignition key to the “ON” position while holding down the trip meter
reset button.
Hold down the button until the light goes
off. Before the light goes off, it illuminates
for 3 seconds, flashes for 2 seconds and
illuminates for 1 second.
If the system fails to reset, the light will
remain flashing.
