Retrofit Fog Light Interference Fix
MTD
So the issues started at the begining of the summer when I first did my FX-R retrofit on my 99' Limited. Long story short is that when the highbeams were turned on they wouldn't turn off unless I shut the lights off completely and turned them back on. A more in depth thread can be found here about the problem:
http://www.toyota-4runner.org/3rd-g...d-gen-limited-retrofit-issue-drl-missing.html
Well the good news is that I think I am on the road to finding a solution! Since i have gotten my h4 harness back from TRS the hi/lo's have been switching perfectly! Today though I was messing around with my fogs and turned them on to make sure that the where working ok (thought a bulb had burnt out), and noticed that when the fogs are on the hi beams stay stuck on!!! If the fogs are off though the hi/lo's switch seamlessly.
If any one has any thoughts or suggestions on where I should head next with this it would be much appreciated! I intend to do a write up on any solution that comes up, because I know I am not the only one with this problem.
wayblom
