Rexing Hardwire Kit on 2021 Limited
Troman62
I imagine this has come up somewhere but I haven't found the right thread.
I just bought my 2021 T4R Limited a Rexing dash cam and the additional hardwire kit. In all of the posts and videos I'm finding they have some other way of doing things. Some use an add-a-fuse connection but that seems to be the old way. The kit I have has the 15 amp fuse connected to the cable permanently and I have seen instructions to just replace a 15 amp fuse in the interior fuse box making sure to check which side is hot. There are only 3 fuses that are 15 amp in that box: Rear Washer, Rear Wiper and Hazard lights.
Who has wired this before and how?
Thanks in advance.
I have the same kit. I did the hazards for constant and just used an the 7.5a ignition switch otherwise. Seems to work just fine for what I needed. Also, if it makes it easier, I put the little box part of the harness inside the pillar cover to keep it out of the way
Great, I'll probably mess with it later this week to give some other people a chance to chime in. Thanks everyone.
Not sure the original post in that thread applies to the 20+ 4runner since they all have the large Safety Sense camera behind the mirror now. Id assume the wiring is different. I could be wrong though.
Dongar Technologies Dash Cam Installation Kit for 2020+ Toyota 4Runner Amazon.com: Dongar Technologies Dash Cam Installation Kit for 2020+ Toyota 4Runner: Electronics is for 2020+. I bought one and ended up hard wiring for the parking record option. But this may work if you’re wanting something a little easier.
