IanB
Active member
I know I'm going to check them tomorrow. I didn't have a gauge on me today so for all I know she had 10 psi in them. If that's the case then I'd just do that too. haha
Running E-load tires at low enough pressures to get the ride you want may lead to cupping or wearing the edges more than the center of the tread, and you don't want that either.
Did you ever confirm which spring perch position your front struts were setup for? The pre-load takes away the softer coils of the progressive rate spring, leaving the harder coils to suck up the bumps, and will feel firmer as a result.
