Right front axle question
jreask
Member
I am replacing the right front axle and the oil seal in the diff needs changing. Actually the seal was bad and the CV was leaking so I decided to change the CV along with the seal. Can anyone tell me how deep to push the new seal in? I tried search and came up with nothing.
1997 4Runner 5 speed 4WD 3.4L V6
If replacing a cv axle you should push it in with the splines lined up till the c ring snaps in place. Take it for a test drive if it makes loud clicking sound when you turn then its not all the way in.
Sorry, maybe I wasn't clear. I am asking if anyone knows how deep to press or push the new oil seal into the diff?
Did you not mark in the diff how far it seats in there? I just changed an axle today and I want to say between 3/4" and 1"; I would think that the diff has a grove in which it resides in.
Another member, J$$$money, has much more experience and he and/or someone else may chime in.
I did look at it, but the PO had some shoddy work done, thus the axle leaking so I am making sure about depth.
If anyone is interested, I installed the seal just flush with the end of the differential tube. I bought the seal from the dealer for $16.50.
So far no leaks. I also replaced the axle while I had it apart. Also the front diff fluid got changed at the same time. Killed THREE birds with one stone.
H.Sikina
