Right front wheel locked up on me
4runn34
Junior Member
Driving to work today I had the right front wheel lock up just as I was braking to pull into the parking lot. I did the Tundra Brake Upgrade a couple months ago so it seems odd the brake caliper would go bad after 2 months. Could it be something with the CV or something else? I'm planning on getting it towed after work and then taking the wheel off at home to see what's going on.
Most likely a bad front caliper. Could also be a collapsed brake hose.
I went out at lunch and got underneath and found the top caliper bolt was missing. So I walked back about 200 yards and found it laying on the road. Torqueing to spec is not enough apparently. When I get home I'll put loctite on all of them. I couldn't imagine having that happen at highway speeds.
Torque is 90 ft lbs. Are you positive that you torqued it? I've never put thread locker on caliper bolts' just anti seize and have never had any issues.
I agree with Spartacus above. I've never put loctite on any brake job I've done and I've never had a problem or a customer comeback. It's also extremely unlikely that the caliper bolt would back out if it was torqued correctly.
2001ATL
