Just read through your build thread and see you are looking at lift options. Last post was a couple months ago so you may have already decided & done the work.
Here is a photo of my 2001 Sport Edition with the Old Man Emu 3" Lift complete from Toytec and a set of BFG AT KO's in 265/75r16. FYI, I did not install the front top plate spacer. Unfortunately I don't have this truck anymore, currently have '06 SE V8 with OME & BFG AT KO2.
I highly recommend Old Man Emu. It rides great! Firm but not uncomfortable. Little to no body roll, no more rear sag, and does not nose dive under heavy braking. As I'm sure you know, you'll want to get the front coil that supports the extra weight of the SW bumper.
Anyway, just thought I'd share a photo to give you an idea of lift height with the 265/75r16 tires.
Cheers!
Cool rig Jordan! Thanks for sharing your pic of how you 4runner sat with the OME lift and 265/75/16s. That STILL is helpful. Very sharp rig!
You would have thought that I had long since gotten everything sorted out. HA! You would be wrong. I have had some divided attention and life economics slow my forward progress down a bit.
Hell, my SW bumper is still sitting in the back of my 1994 Extra Cab... The truck that needs to be sold. However I knew I needed to replace the 94's radiator. I got that swapped out with a little drama. Then the battery needed a good trickle charge to bring it back to life after sitting for a spell. Just yesterday I called up my friend and said that I was coming over to drop the bumper off so that we could put it on the Runner later. I checked everything over on the 94 since I had not really driven it since I swapped out the radiator. I cranked it up, backed it out of the garage, popped the hood, and it didn't take too long to find a suspicious red radiator fluid leak somewhere along the engine, further back from the radiator. The hell! So back in the garage it went till I can devote some more attention to it.
So I sort of have two projects cooking at the same time. Just in real.... slow.... motion... LOL.
I got my first B&M trans cooler stolen from my front porch. F#*@!! Amazon was cool and sent another. But, I feel uneasy about sending my order for other wanted parts, (LBJs, lift), and not being home to greet it. I will probably just have it sent to my friend's house.
I am still considering all lift options atm. I though that I wanted to go coilover upfront to accommodate the desired mild lift that I was looking for, but with the added weight of the new SW bumper. I am not above looking more closely into the OME lift though. I do a fair amount of highway driving, so whatever it is can't be jarring. I would be tempted to even look more closely at the SS 1.2 lift, but that rake with 265/75/16s seems a bit extreme in some pics that I have seen.
The most exciting thing I have done for my 4Runner has been to change the oil and change the air filter. I was rewarded by earning a CEL with my old friend the P0420 code! Yay! I had already changed out the rear O2 sensor. Now it looks like I will give the front Air/Fuel sensor an update.
Life hates sandcastles...
