I have a 2016 TE with 6112's set at the second groove. My concern is that it has really bad pull from the road crown. The worse the crown the worse the pull. I've had it long enough now to confirm it's the crown and none of the other possible culprits. After I installed the front coil overs my post alignment caster was 2.6 on the right and 2.3 on the left. Before I go back to the dealer that did the alignment I'd like to arm myself with some info.
What do others say on this and should I just get Camburg UCA's as the first step.
Thanks.
Thanks.
