Rocks & Flops: a 1-Ton SAS Build
Fabbing together the "grasshopper" cantilever suspension.
For the spindles I used Trail-Gear's Swingout Spindle Kit (part number 306503-KIT). The small notch in the frame was necessary to keep the coilover springs from interfering when flexed.
img_8545-jpg.1053318
img_8546-jpg.1053319
img_8773-jpg.1053323
img_8784-jpg.1053320
img_8857-jpg.1053321
img_8871-jpg.1053325
That is freaking awesome! I've seen people talk about cantilever rear setups, but never seen one follow through. That video is sweet! How much travel did you wind up getting?
In order to get the rear triangulated 4-link to fit properly, I swapped in an F150 fuel tank (Spectra Premium part number F1G1FA).
I wanted the fuel gauge on the dash to work like stock, so I made a bracket that can attach the Toyota sending unit to the Ford fuel pump. The float arm required some modification to fit right.
dsc01914-jpeg.1058944
Installing the fuel tank using the eimkeith bracket kit (had to lower it all ~1/2” to fit under the cab).
img_8985-jpeg.1058945
For the filler neck, I reused the stock cap and used a 2” (not so) flexible fuel hose (24” long) from O’Reilly to connect to the tank. The tank vent is made from 1/2” fuel hose, connecting to a barb on the tank (McMaster-Carr part numbers 5463K86 and 1171N201).
img_8959-jpeg.1058963
All hooked up.
img_8971-jpeg.1058974
I pulled it out of the garage for the first time in a long time and gave it a much needed wash.
img_8997-jpg.1079651
Without the fenders trimmed, the 4runner really couldn't do anything other than go straight. Nothing an angle grinder, sawzall, mini sledge hammer, and a welder couldn't fix.
First I ripped off the limited fender trim (with the amount of up-travel I have there was no way I was going to be able to make that trim work out). Then I started cutting only what was necessary from the body at full suspension flex (I don't have a photo of it, but I used a stencil made from posterboard mounted to the hub to mark out where I needed to cut so I didn't have to keep mounting and dismounting the wheel/tire).
img_9439-jpg.1079661
I didn't really like how the rear doorline was turning out, so I cut slightly into the door to blend the lines a little better. I was liking these lines much better.
img_9447-jpg.1079665
img_9454-jpg.1079667
img_9456-1-jpg.1079671
Then patched it all with 18 gauge sheet metal (this all really sucked doing by the way, definitely my least favorite task).
img_9629-jpg.1079669
img_9630-jpg.1079672
img_9631-jpg.1079674
I then painted it with Dupli-color Perfect Match in Natural White (btw I was really impressed with how close the color match was). After painting both the outside and wheel well fenders in white, I then painted the wheel wells with some black rubberized undercoating. To finish it all off, I added some thin black fender trim (Cowles Protekto-Trim 39-511-01).
img_0414-jpg.1079678
With the custom front frame section I need to build a custom front bumper. I’ve spent quite a bit of time designing it in SolidWorks, I want a low-profile plate style bumper with an excellent approach angle.
I’m incorporating in some Baja Designs Squadron Pros and S8 lights (part numbers 597815 and 702013), and a Comeup Seal Slim 9.5rs Winch.
This is what I came up with. All structural pieces are made from 1/4” steel, recovery points are 3/4” and plates are 11 gauge. The bumper itself is removable from the front frame using six 1/2” bolts.
img_9552-jpg.1079702
img_9553-jpg.1079703
img_9562-jpg.1079704
img_9607-jpg.1079705
img_9612-jpg.1079706
The stock master cylinder can’t cut it with the size of the brakes from these 1-ton axles and these 40” tires. To solve that, I swapped in a master cylinder from a late 80s Suburban, ACDelco part number 18M1884 (it has a 1-1/4” bore, as compared to the OEM 13/16” bore, so the stopping power of this new MC is 2.37x that of stock). The brake booster is stock though (dual diaphragm booster, should be able to handle the new MC).
The bolt hole spacing on the Suburban master cylinder is slightly wider than the two bolts on my booster, so I had to wallow out the holes a little using a dremel.
img_9016-jpeg.1057802
The plunger on the booster also had to be shaved down a little.
img_9010-jpeg.1057798
img_9011-jpeg.1057799
img_9012-jpeg.1057801
I also installed a Wilwood proportioning valve (part number 260-10922) for the line going to the rear brakes.
img_9017-jpeg.1057805
I replaced nearly all the brake lines on the 4runner, I used some 3/16” copper-nickel line and double flared all the connecting points.
I also had some custom flexible lines made from a local shop (Crown Performance) go from the frame to a T on each axle housing, plus flexible lines were installed at all 4 calipers (6 total flexible lines).
img_8465-jpeg.1057797
The S8 lights are good on output. I run a 30" S8 bar with the lenses swapped around a bit to get the wide/spot mix that works for me (2x combo, 1x wide). It basically replaces the bottom 'bar' on my grill.
What are your plans for accessing the winch clutch lever? Also, it is nice to have a 'window' to view the winch drum to check how the line is spooling up (both during a pull and when re-spooling later).
-Charlie
[MENTION=139000]phattyduck[/MENTION]
This picture probably doesn’t show it well, but you can see the drum/line fairly well at the bottom of the grill.
full
In order to activate the clutch on the winch, I have to open the hood and reach behind the grill to turn it.
full
I will be the first to admit it is not the most practical solution, but these clutch levers on the ComeUp winches are easy to turn (can easily be done with 2 fingers). If I find it tough to turn on the trail I’ll either 3d print an extension or plumb in an air clutch.
I wish I could give a real-world trip report on how it was operating the winch while doing the Rubicon trail recently, but the winch never got used, lol.
That all looks good. My winch control box sits right about where you have to reach in to turn your clutch, so my hood has to be open (at least popped) to operate the winch with wired controls... I liked that better than having it sit out in the open in front of the grill. I spend to much time in the 'city' to have winch parts easily accessible like that.
-Charlie
Like I mentioned in my previous post, I took the 4Runner to the Rubicon trail recently. It was a good shake down for the rig. My wife and 2.5yo son joined and we got a few solid camping/wheeling days out of it. We drove it to and from the trail from San Diego, no trailering. Thankfully we literally had zero issues with the rig, here are some photos from the trail:
img_0572_original-jpeg.1079776
img_0578_original-jpeg.1079779
img_0634_original-jpeg.1079781
img_0273-jpeg.1079782
img_0274-jpeg.1079783
img_4992-jpeg.1079785
Holy smokes that is rad! Fantastic work. I was having an issue loading up pics and I was going through previous posts, amazing. Welding sheet metal is fun they said.....
The fuel fill hose, is it like a radiator hose or is it mildly thick with wire support similar to gates # 23924?
You mentioned you used generic parts store fuel filler hose. Keep an eye on it. When I did my f150 swap I used similar hose (fuel filler neck hose, like radiator hose) and the hose dried and cracked, then puked gallons of freshly billion dollar fuel.
[MENTION=405460]2TH4IST[/MENTION] My fuel hose is a "flexible" (not really) 2in wire re-enforced fuel filler hose I got from my local O'reilly. It's not perfect, but it's working now so I'm not going to mess with it unless it starts to become an issue.
mek
