Roof rack lights... how to run wires?
67siia
Tomorrow, I plan on wiring the 4 Hellas lights on the roof rack. Does anyone has any suggestions on how to run the wires from the rack to the engine bay? I have not been able to find any good recommendations, I would like it to look clean.
I would offer advise...but my guess is as good as yours. Looks like you might be on your own for this DIY.
Post pics when you figure it out.
Good luck,
-Shawn
That is great, I may do that when installing the GPS antenna... the lights unfortunately were installed over the weekend and not as a clean install as this one.... I'll post pics soon
send to Toyota
This is an incredibly brilliant install.
How is the factory optioned Sirius/XM installed? If it is mounted externally, I would send this to Toyota.
Too bad it does not work on my 3rd Gen.
Err... Does that GPS thingy in that thread even work? At least it must get a bad reception at some places...
Anywho, I just drilled a hole and used some special stuff that I don't remember the english word over.... You basically drill a hole for it, put it in the hole, put the plastic nut against it on the other side, put the wire through, and screw the other end of it so it tightens to the wires and seals 'em. Works okay, but doesn't look good if it isn't easy to "cover" it behind the roof rack.
That method showed in the thread, well, it's brilliant, until it fails. And believe me, it does. I've seen this and done this so many times at work. And sometimes things don't even last the year. But maybe the weathers are abit more extreme over here along with the salt on the roads 9 months a year. =)
If you like it on the other hand, then go for it, in worst case, you'll have it broken in few years/months and have to fix it or find some other solution. =)
Also, run big enough wires for the lamps and dont ground it on the top, take it down to the engine bay or inside car before you ground it, otherwise you'll have rust problems. =)
