Roozter's '16 SR5P Stealth Runner
roozter
This thread will document the build of our (my wife's) new 2016 SR5 Premium in Midnight Black. We picked it up on 2/18/16 with 7 miles on it. The first build mods will begin with less than 150 miles.
Completed as of 03/14/2016
Roof Rail Black Out & Front Window Tint
3" BOSS Toytec Lift with SPC Light Racing UCAs
Lift Pics: Before & After
285/70/17 Nitto Trail Grapplers on Fuel Octane Black Wheels 17 x 8.5 -5 backspacing
Salex Center Console Organizer
NFab Step Bars
Bushwacker Pocket Flares
Emblem Black Out
TRD Pro CAI
LED Hood Light Kit
As of 10/22/16
y3miNulGYQ4Ycj74ZbQhHT6LdnJa8L436LWXaqXdDDqMXRjqfWaUs_pqtTvtLJERdHr3dchSC17CO7rUSguzU0WT_iTxSchS4EseH3xURFWMggmcCGLrBVfFtuC6tv-RzqCjPHAKnaVSxR-EO9IFE-eIXzduwbnTaJIjij8rLhsag8
y3mEqoksSY646ELyD1dz-CcUgCmb1dJYc8vaj3XM2NLvulmscGMhHVcOiL0RTDqW7wowJ6yzfFk-gYXNetSi1wlpMqDVdorHt9fXJlMB9jkR6xuil6XoRwWh1ngN2tzy51O5QDynfXl0B9ZGMPo6IyzBgyTOOJxMLxvpxiYErizxQM
3" BOSS Toytec Lift 5th Gen
Got some goodies from the FedEx guy today. Can't wait to install on Saturday and reference all the great info here!
y3myyUUzY2LqqBcjqa92_dyBHneyUKX7JBU9zfOCGcgmbbq-stATlkeEi245c6IgYFPHxYo4rvqbIzZ5XGRg2HD6Ksb2vF7vrqnEoGF2WmnvCOO7ezxyv0viiBLwK4DOyYVZ7OAdFFWMOubCO5iOTy8_41E2iOsaFj_R1ztfaBbbzY
Are you going to go up the full 3" in the front?
If so, you may need to change your UCA's to get your alignment in spec.
Maybe someone that has done this can chime in if your answer is yes to 3" lift....
I want to go up the full 3". But it depends on how it sits. Obviously, I don't want the front higher than the rear. I have the Light Racing UCAs that are adjustable. Those will work, right? I sure hope I don't have to have other UCAs. :-o
Pics with Roof Rail Black Out and Front Window Tint (legal). I had the dealer do these because: 1. I don't do window tint. 2. I didn't want to do the black out for emblems and roof rails. Also the price was reasonable when I included it with my vehicle purchase. I do have some bubbles in the tint and it has been 3 days, so I'll have them redo the tint when I get the emblems blacked out.
y3mxocz4sXFX46yZSS-j3K3lLlLWzdyrn5FBla_zCzmVu2x7KDlrkrJyVNZp7b7i1FYNCa3nZZxsGeBHFbD0lgZ7QZuFmmyP3i1H2oI95Xd6RftKBNnUU44A0Ln_fA93KnwmzdOZwuFdE02usfJyxQ40QyiN_HrqaMhzI7uqd3UlnM
y3mrvXqr3Z53Kh-CMs4DruvpEwQVctiPw5ncZe8TsO2PTujnT2xN3dFb8jBJFfAVufbpGmdW1JIJRl0yryBJvc_RT95pw4r1l-tsfMKWq-5x9nxOEXxSaW2I2r6FPIwIeCfUpgWepRTVxWaHBwKjdXwhdtB6ZGEAjo_OHrr9KmcuZQ
y3mDaSwKz5Gz197b2lZpUNRzwLrQMA3UNPKEtc0yHqKO0_Xm5RF8v1BzdJC7KhBadJh8XQ-Xt_l0IXtLNc8Gt6iZpE1-WUPCUj6YfzwVCLJsDl3VboIt5Q30cTYqPeRu03Pphul2AF7sGjwtbbPrco9BSr4oanlWR7fvbEVZOaluws
boy, they don't let y'all get by with much on the window tint do they? mine came with 25% on the front and 15% on the back
Over the weekend, I installed the Toytec BOSS 3" lift, SPC Light Racing UCAs and had the NITTO Trail Grapplers 285/70/R17 mounted on the FUEL Octane 17 x 8.5 wheels.
It took me 14 hours to install the lift and UCAs including the diff drop, front sway bar drop, radiator bracket drop and rear bump stop drops. I did 80% of it by myself. I had my 13 year old son for a few hours (mostly watching). I gave him some time with the air tools and tried to explain what I was doing but he was not super interested. My wife helped me with the UCAs and kept me company til midnight on Friday night.
I found a lot of great info on installing these lifts but it was somewhat fragmented across several threads. I took some pictures and made some notes on things that were either not mentioned in the installation instructions from Toytec or that I have not found pics and details on the forum.
Some of my notes:
1. Make sure you have your vehicle supported properly and safely. I did not have any problems with this, but I did take about an hour and a half jacking up and supporting my vehicle including removing the wheels.
2. I did one wheel at a time for a couple of reasons. First, I am not a professional mechanic and I didn't want to mix parts or get confused. Second, I was working by myself and this just made more sense to me.
3. You will absolutely need a helper for replacing UCAs. There just is no way to pull the bolt out from the engine compartment and hold the UCA / wiggle it from down by the hub assembly.
4. If you don't have a torque wrench rent one for free from O'Reilly or Autozone. IT'S FREE.
5. Just rent spring compressors for the rear springs. IT'S FREE. Why mess around with shade tree and potentially unsafe alternatives. Even though I used spring compressors the heavy duty rear springs still required me to jack up the opposite side of the rear axle from where I was working with the rear sway bar disconnected. When you use the spring compressor keep the bolt heads facing the ground it will make removal easier. I had them facing up the first time and I could remove them but it was a PITA. Also, spend some time planning how you will position them keeping in mind the bolts will come out the other side of the spring holder and depending on how much you compress they could contact the vehicle when you try to install them.
6. Air tools make the job so much more pleasant. I also had the pleasure of working on a brand new vehicle (150 miles). It was like butta!!
7. Mechanics gloves make the job easier on your hands.
8. Take your time to thread the bolts into the aluminum spacer blocks. I got one bolt a little crooked on the sway bar spacer and nearly cross-threaded it. I had to use some force to keep it straight and then my air ratchet to drive it in straight
Step 1 - Remove Skid Plates: Remove the front plastic under bumper cover, front skid plate and rear skid plate.
y3mr9w8CWTD7XUds1m8pLFqEAaLs21wb8e05HuBi_Vvk7z5eJVeGEDtaimLrwcw7MnzEUJGBetgz8DO5Syb8cb2KMfDwKfEENw4o-RqLgPW0ty4ghQCvtDTS7SKtf7IghJ00Zaxi5QL-UaorJk71gWQHmW6e4mnmmxBpMga2kMPnhU
y3m0xJd6q9oRSzkfJkq0XAP_cVkx-04guK7qhvyWQ6Bv0-h5BqDxwZDWoXasyuJPWDahxJOzceQWfmXDhi97UOitOAMaFp3a9oAaQBtUhgDW0HVihWKWN7mVISB7JmIZ369VtbJsOLWsvNcoOxQtScgp8grwu7Ts68fYjXUORIm0PM
y3mqIRs7WPn9Az-sBIr7VytkMWfIJeTY5x28BgEHsZoFuv9l5bFCUY98o90jwvScPwXCnJaIFqhWvcyACbDQi99x1SrSn6DShwqzLW7iVK3vomlnF9k56hMDUUaM2k2Ujku8puCYCphBymGRdhaU77F2M4A7pQSpHxBKIxIA_pCabM
Step 2 - Support the vehicle: Front jack point. You will need a hi-lift floor jack or you will need to use the bottle jack on some bricks / blocks of wood. My orange harbor freight 3 ton floor jack was about 2" too short.
y3mrgTUEoHZv9eVfaN4sk_jry7YLZpZRAEjaM0-pil5HYAmn9S2ZkgqEFraXx_9ZL8Wov2BnDXFdcVExZIaH3rGGVw05JA4mCtIu1LN_IkTYIpi6giRxx8UwotTzkhpbByJTT9HIslkVOkUx1_A9UXPR1L6ZPdqlzh7qmPhbsI1wmI
Pic of my vehicle on jack stands.
y3mSMkUjKC5RowSLVT_bHEvvbIhFkxXmhoNo7UPGQoIEpyubLATeIeZaJd-BszSnksZHSXTu8-XniaC99ACdM2SZbbr3zjCaOylBByhawVn7k475UGW2_uR2zSkWUF737JgVfixvj85D26yIT3Pgb6lPzeqBy-lwUJb9LQKAMXg8wM
Step 3 - Disconnect Sway Bar: Disconnect and remove front sway bar. Since I was going to install sway bar spacers it was easy to just remove the sway bar at this time. I don't have pics of the sway bar but that should be easy to find. :wink2:
Sway Bar End Links
y3msIZp4BgWb_9B4PYstqm0kjCa6I_cSN8_jtJnpCPNLQt2f63nWV9imrCDqjHju7TiKQNBXkEhoUPduAEMaeadzrt_WYpRTSkZJnvKBSuJisR2Hcu_OnHXGjG1Kk3G8RdaV6XGe5nMvfFMlp8q-GO_7aPNzEoBzMqh9DQKVSyd-6k
y3mRYpVmfhuAQTwlzZMbsARyXFyd-q_qbD0J3dI1nVwN1oXbS_dVVPrPqeQBlcmOl34BPYS09Rq7N-Uh60Spzf4a3DGv7R2P9Zenyt_FMnAfEwxLOtycSAJJjOZtwNnb1Y7DUBRIgczoyumUk2Clh7OacKA1w1bEyymfmEjYLZOuAM
Step 4 - Disconnect ABS Sensor: Disconnect the ABS Wire at the hub, the lower bracket, the plastic clip and the upper bracket. I pulled the wire connector and wire up into the engine compartment to avoid stretching and breaking it. Lots of info on here about breaking them ($50 each to replace) but I have not seen any pics.
ABS sensor connector at the hub. I had to use a small flat blade screwdriver to gently pry up the tab that was holding the connector because I could not figure out where to squeeze to release it.
y3mv6dPoU5jrvr2-4Mu_A4_Yn7CcgBTh7hINtk2rUJnk0mnTk3F9f3TMUYiLWtBckqVFzN0U4VSODSFJGvTwd82kTx-toOdLHUpkTzudWQTKVhU4KYj7lb5GvICfiXWDuXVr0iZCMgLzO3G2EZGvDIza-1sjgK8XlKDGneVzxgPdZ0
Remove the lower bracket.
y3mbqH5p1T-Pg6NLFDXsTtKm6EM-np2E3AKx3YPSbOzZSuO6WQ6oozr87t3p939KUk_LI1Mdz3IgWH274dFr9y48bZL6Rlc1wOd3-j8LiwV5M4pDK9xrUokyQVR8h5rRteYZ8d2cx1TYzip4VJmOqS1DhntaY2TRl-3D3L79KcDSL0
I used pliers to gently squeeze the tabs on the backside of this plastic connector and remove it.
y3m1Vyx4X2xpY1wwgD_YMI-m-wtHS6CwQC2xwF_adCKZE3fuCFliWK49PcFAlQzmwn4bvlianHuJzqjDpRGxTWsdgcWyMoRc_oib6v79QkOiXllQQSAfe2AEkLFfEeOkyZy9YhpeBkw9IAEPvhJjknZ3sPvgfEnOAVIZXTMh382e4w
Remove the upper bracket on the UCA. Since I was replacing my UCAs I was going to need to remove all these connectors for the ABS wire anyway.
y3mhg7bNw30J7WEacEHhy3gx_ebaGLBYwiVe7sdO_SveJeBxIAwjoFu1NFcwOO_KXUVYvSWkN3ewCSZ1YMtQ2W-G1DUfSZzUh_vt4UaTOBF_gr0pwtzqv37rD1IJO33rZywSC3ObJYLM8coYPBXWAIVV6WCNzvnONmNvR108azBTT0
I gently pulled the wire up into the engine compartment through this opening in the fender.
y3m6DpfJTacFCJF6H4C2yHE5sEIrwmLY5jgJDSuN5wP4CPcCb4OuQFlRAKHpRKmuIt_jpY5stle4ZnLv2OUygGqsFEJNQeJk0AdgX8PHprm_aNjH8zZrrKuxZtCqo94ZFKBDJwVXHPtF2GBkF3cunjGxVhXc03RZq8X4io4mKVJDaM
I tried to trace the wire in red looking down into engine compartment.
y3mk5apg0uCME4UaYku83Bg3fkTH-tLHRsLwTHeOrIzwULTUpAL9itRs_EuzHuI__mFecC32I_tzzuFvsZ8XUi49XBaaVWbkiXPLWKgOFZ5VbpoBk4FMktzLKmvp84rFIUDinxIex1MEaAHleiMObGIB6xPIOkyHv50kPAbsO-RfWY
Step 5 - Front Coil Overs: Begin using the instructions from Toytec they cover everything you need at this point. I also replaced the Upper Control Arms and I tried each front wheel differently. The instructions on the UCAs were adequate. Driver's side I replaced the coil over first and then the UCA. Passenger side I removed the UCA and then the coil over at the same time. I think removing the UCA and then the coil over was easier because you have more room, but you will need a helper and/or a good strategy for supporting the hub because it will only be attached by the CV joint and the steering linkage at this point. I used my floor jack under the rotor with a block of wood between the jack and rotor to support the hub assembly. Then I used a cargo strap to keep it from moving around too much.
From this point you just re-assemble in reverse. The instructions for the differential drop, sway bar drop and radiator bracket drop were adequate.
Step 6 - Rear Shocks and Springs: The rear was much easier than the front because there is less to disconnect / reconnect. The rear took me 4 hours from start to vehicle back on the ground.
I did not take pics of the rear until the finished install. The Toytec instructions are good enough. I did not rent a coil spring compressor before I started but after using a pry bar to pry the stock spring out of the driver rear and then seeing that the Toytec HD Springs were a good 2- 3 " taller I said enough, go rent a spring compressor. I did not disconnect the pan hard which I read as a method on another thread. I did use my floor jack on the opposite side of the axle to cause the hub to drop lower on the side where I was working. Just be careful when you are doing the second spring because you could end up raising the vehicle off your supporting jack stands when jacking up against the new stronger coil.
y3mZoQrFuu7ulF8D55m8B2m_y6Ywe0e3rKBYRAzw8Kdmo_Z6b68KSM2q5ZyxTL1EsVUJ3IQqdFXHda6UOb3xtvuWWV2fo1rZFPUMt51WPFJCvHtH_Cxuz3KS8h2tUjVMYWsMXEiaQFVXKoNOzmcWH_lljgzBvuZ3ysuotN11nErDEY
Lift Before & After Pics
Here are the pics of Stock vs after the 3" Toytec. I am still waiting for the coil overs to settle and then adjust the front. The rear looks higher than the front to me.
Before
y3ml_6NbvsHQdYlYZwk-d8SIuh5ZHA8puSzmZsH7Szy5JeZdPELpGShwoRvqT53nJxid5PiwJ7GKk-X2Y8AXAddcMYPGywEDbSG5lGDRW1ZwaxE0c7bsG7ntiNRnhtxItHky21ZsfN1RAkc8KSd5oVfine5q9Z6Cf1nGrObgbukd_s
After
y3mQCzqkIYofhVSybuhPCmmANL0jUOrr3ydi-lVGu4kklcY6LV0I93dGsuGIu_wZVstl1P3mLvOP5QwtT0YMWg60vwEcHYzqbso61tuHJin5BJhmX0QXuBacaCjeU8GtTYKWsjUhD3i9l0n328EJ7v8-TQ4I2sVmBCrILpU30_FtPA
NFab Step Bars
Got the best price from 4 Wheel Parts and they have a location about 20 mins from me. $366.99 with 10% off coupon.
This was as easy as the center console mod. 5 bolts on each side and I was done in 20 minutes!
Yeah it looks like you've got a pretty decent rake going on there to me but the angle and possibly the turn of the front wheels might be accentuating that. In any case, nice write up and congrats on the new lift!
Thanks! Yeah you are right that the angle and wheels turned might be throwing it off. I'll take another pic straight on. I was trying to duplicate the stock pic angle and turn of wheels. I should have taken the stock pic straight on. Maybe I have one somewhere. :doh:
Another thought I had, you might want to think about leveling a bit now as opposed to waiting so you get a more even distribution on those rear springs. I'd wager that Toytec has done their homework as far as where the springs will settle and you'll get a faster result by giving the rear springs the distribution they'll eventually have to handle when level.
Just a thought. Someone with this setup and / or more experience can chime in and correct me.
Found out why the rake is so bad. I incorrectly ordered and installed the HD Coils in the rear. I thought it would be good for occasional trailer towing. The HD coils are supposed to be for regularly carrying an extra 200 - 300 lbs on the rear. :ohwell:
Now I need to buy the regular toytec coils or maybe someone wants to trade.
Hi man, nice truck :) but can't you just lift the front a bit more ? Isn't Boss adjustable in the front ? But hey that's just me.
Maybe you just need to buy some other mods that are heavy. :D
I wish... Called Toytec. I adjusted the front to 3" of lift and they said that is max and I can't add spacers, 3" is max.
seltzernator
