snif6969
This.I agree - sorta.
I ran 5100's on my 2010 for 7 years and I loved them. I'd describe them as somewhat firmer than stock. No way did I think they were rough. Mine is a DD, and I thought they were a great improvement over stock.
@OP. Do you know what an E-rated tire is?
FYI:
Identification: The load range is identified by a letter of the alphabet, usually from A to F, which represents the ply rating and load pressure. A rating of "E" on the tire means the tire has a ply rating 10 and a load pressure of 80 psi.
Vehicle Type:
The "E" designation for the load rating of the tires is only used on light truck tires, not passenger tires. You can identify whether a tire is a passenger tire or a light truck tire by looking at the start of the service description on the sidewall: passenger tires start with a "P" and light truck tires start with an "LT."
Significance:
"E" signifies one of the highest load ranges available. You may need a tire rated this high if you carry heavy loads with your truck.
My $.02 is that your issue is 75% tire, 25% shocks.
I have 5100s and 6100s but a dead ass soft sidewall on my Nittos.
If you want a smoochie tire get the Nittos Terra
Sent from my OnePlus 5T using Tapatalk
