Rowher Flats - Lookout to Boquet Canyon
Drunner97
While the rest of you hanging out in Big Bear, I tagged along with the TW crew to go check out Rowher Flats in the name of a potential run there and to check out something a little closer to home (1 hr 15 mins vs 2 - 2 1/2 hours)
The Good:
There's plenty of camping across 3 staging areas. We were setup in the 3rd staging area and could easily park all of our rigs there plus there was ample camping space along with a pit toilet.
The Bad:
Both Lookout and Rowher flats leaving from the staging areas are very much black diamond and require 4wd. Rowher MIGHT be doable going up locked, but lookout definitely is not. There is a 2wd friendly fire road that allows you to go around a lot of the stuff from the Boquet Canyon side to get up to Lookout point. From there you can take Rowher back down. I wouldn't suggest taking Lookout down without low range 4wd.
The rangers do patrol the staging areas and you need a 5 dollar adventure pass. They will ticket you for it.
It was bloody hot. The 4runner said 98 at one point, and another Tacoma said his hit 102. So this might not be a good July or August run. Hard to say what the weather will do though. There were 2 spots at the staging area 3 with shade and fire pits, didn't get a good look at the other 2.
That being said, here's a look at Lookout to Boquet Canyon, back up Boquet to lookout point, and down Rowher trail. The part where I pass the black Tacoma on the right (towards the beginning) is where [MENTION=136692]SixthSnail[/MENTION] almost binned it.
Dang Drunner, you just weed me out! LOL!
Sent from my SM-G920P using Tapatalk
My understanding is that there's a ton of 2wd friendly fire roads in the area, along with at least one that leads up to Lookout Point. I think we only had the 1 2wd truck (with stock elocker) with us, and I'm pretty sure they took that up to the top to meet us.
There is a high clearance 2wd accessible fire road that goes up from Bouquet Cyn Rd to the top of Lookout Mountain. Its called Artesian Springs Rd. There is a harder trail up to the top as well from Bouquet and it crosses the fire road in a few spots. The top of Lookout has great views! There used to be an actual lookout tower for the forestry/fire service and the foundation is still there along with some survey markers - very cool to see.
I would not recommend going down either Rowher or Lookout to get to the Sierra Hwy side without a low range...its very steep in places and would be very hard on your braking system
I'm glad I stumbled upon this forum...looking forward to wheelin with you guys
Rowher coming down wasn't too bad, that's the 2wd guy in front of me at the end of the video. My GoPro battery died when we got to the hill climbs so I didn't catch the rest of the trail, but it wasn't bad.
looks like he had a good sized lift and tires - I would just be worried about brake fade going down some of those hills without a low range, but, like you said, Rowher isn't as steep as Lookout
Rowher is in my back yard. I had a bad experience out there.
I was testing out my SAS and broke a break line near the top of the hill. I didn't know it until I started back down and had no brakes.
I jumped it about 50 feet from the same bump that snapped my stainless brake line and luckily when I landed it snapped the front axle. It acted line a boat anchor and kept me from going the rest of the way down the mountain.
Jesus, that was you? I saw that story posted somewhere else a looooooooong time ago when I was researching off road trails.
NVBASSJUNKIE
