rubber brake lines ?
Gstick
Member
Could someone Please give me the OEM part #'s for the LR & RR rubber caliper lines ?
This would be for a 2010 SR5 4x4.
I also need the part # for the CENTER rubber brake line. (above the rear differential)
Thank You !
Are the 2010-2013 brake lines the same as the 2014+ models? I read someplace they wernt and that the 2014 and up have a firmer brake feel. Was thinking of replacing with steel brake lines when I do my brakes.
OP why not just buy aftermarket steel lines if your gonna replace the stock ones anyway?
Toyota Parts Center Online | Genuine Toyota Parts & Accessories just put in your location. Select shop online and select your car, then click Brakes and use the search function -brake lines. You should get your answer there along with a pic.
Thank You !
Not sure we can put steel lines in those locations. They need to flex when turning or hitting a bump.
Are there upgraded tougher lines for the 2014+ that will work and help reduce the soft feel?
utkrstam
