Running 75w140 in the rear diff a bad idea?
jman11788
Member
I will be installing a new diff this week with 4.88s and an e locker. I keep seeing and hearing of people with diff failures. My 4.88 just failed with 75w90 Lucas hd fluid after 2 months. I really can't afford to have this happen again. Wondering if the heavier duty fluid will help with wear on the bearings. I know the redline and amsoil stuff is good. Should I just try that? I don't mind suffering mpg if it's helps with wear.
There is no way the "wrong" diff oil would cause a properly set-up diff to fail. What failed? Are you having the same shop set the new diff up?
ECGS recommends Lucas Non-Syn 85w-140 for Gears and Lockers.
I have been running that for almost 2 years with no issues.
If you were running a used diff with that many miles on it I do not think the issue was the diff oil.
I've run wallyworlds full synth 75-140 for over 100k miles, zero issues. It's not as thick as it would seem so go for it. :cowboy:
Why not use what Toyota recommends?
Seems to work for millions of trucks.
Something else might work, but it won't work "better".
delislerebecca
