Don't disagree with you there, its just sad that their quality is starting to spiral down the drain. I mean every 4th gen trim came with the "flick start" function, but apparently its not warranted on the 5th gens; yet Chevy has it on all their vehicles? The amount of cost cutting vs. features is somewhat disturbing. While I would never recommend a Chry-Corp pile of crap to anyone, it is amazing what you get for the money you spend on it (granted they fall apart and have numerous issues as a result...)
I agree with you on that, I have been pointing out to many that Toyota's quality is starting to slip down a dark path and their warranty coverage is getting more and more stingy. Look at their TSBs regarding "self-sealing water pumps" and their criteria for shock replacement where it basically has to be bleeding down more than half the shock body before they even consider it an issue. As technicians we can't even acknowledge a fluid leak on a vehicle unless its dripping because Toyota will not cover "seepage." These are all lazy & blatantly obvious avoidance tactics used to side-step obvious quality issues. Instead of admitting that their water pump seals/gaskets are not a good design they release a BS line about how they can seal themselves and don't need to be replaced until the leak excessively (which by them means the entire bottom of the engine looks like a pink alien forest.)
Unfortunately Toyota even with their slipping quality is still one of the better manufacturers out there, which is why I still recommend them to others (though now I do so with an Asterisk warning.) This isn't isolated to Toyota, its the direction many companies are going, where they are inflating prices, reducing content, reducing quality, and tightening their warranty in an attempt to maximize profits.
An example of Toyota's Warranty stance:
http://www.rav4world.com/tsb/2011/T-SB-0117-11.pdf
Notice what they consider "possible
temporary leaks!" I don't care what idiotic engineer spewed his BS on this TSB and called it justification for why the pumps are "self-sealing" it makes absolutely no sense. They even state that while grooves and wear occurs on the plate once it pushes the debris out it will somehow seal itself even though now the sealing surface is now marred.
Perhaps [MENTION=66316]1engineer[/MENTION] (more calling on him for his experience as an engineer than putting him down, just to be clear) can help me comprehend this, because I just don't speak this Toyota Engineer's BS. Its pretty cut and dry to me from experience and design, if a sealing surface is marred, it leaks and cannot stop leaking unless an outside force corrects the imperfection (i.e. use of FIPG, replace the sealing surface, refinish the sealing surface, ect.)
Here's their Shock Absorber Replacement Criteria TSB:
While I understand shocks will sweat some, the basic principle is simple with shocks; they have gas and liquid inside of them. Typically the Gas is a smaller molecule than the liquid hydraulic fluid (based on my knowledge that most every shock is Nitrogen charged) so if the shock is leaking enough that fluid is getting out; do you think that gas charge isn't already starting to leak out? So if its getting to close to 1/2 down the strut I would consider that shock's performance to be severely compromised, wouldn't you? I mean its not like shocks help reduce stopping distance or provide stability in emergency maneuvers right?
