SAS for 1st gen ?
or you could find an 85 for 1500 bucks. then you would have a bad ass rig like mine with all the spare parts you could ask for!
easier to just buy a 85 rolling chassis i have two for sale right now for 1,000$ so they are not that hard to find if you just look and wait you can find one with a crap body and just trow your nice body on it.
its a waiting game but well worth it in the end.
the SASwap is costly and if not done by someone who has practice and patience can be deadly wrong if you plan to drive it down the road.
the slightest wrong measurement will cause it to dog track down the road.
These are the minimum parts you'd need to do it:
solid axle - $250
x-over steering kit - $400
front spring hanger kit - $190
springs - $300
add a few hundred $ more for odds and ends.
I did one years ago. It is not hard to do if you have some fabrication skills. I used stock yota rears up front and swapped to Chevy rears. Trail gears cross over steering, shock hoops and rear mounts. Everything else I made myself. We came in under 1k easily. But we collected parts for a while anticipating the build.
I used it as a teaching project for my son too, so that cannot be priced.
solid axle - $250
springs - $300
A SAS would be much cheaper than that though using Junkyard gold. I really want to do one in the near future buuuuut I can guarantee the other half wont let me spend that much on my truck... not in one fell swoop anyway heh >_< Has anyone done a swap using only parts scavenged from a scrapyard? I'm betting you could probably get the cost down to low 200's!
The problem with junkyard parts is the time and money you'd need to invest in getting them ready to put on the truck (clean and paint and seals and bushings and whatnot). You can scrounge parts and make your own stuff and save some coin, but you generally get what you pay for, and sooner or later you pay for what you get. ;):
Just thinking out loud, I could probably score a complete early front axle for around $100. I just picked up a set of 3" lift leaf springs for $20. I know a couple guys that would probably let me use their shops (and their scrap bins) to make things like hangers and shackles. You'll be $50 bucks into hardware, bolts and washers and bushings and things, but you'd still need to scare up high steer stuff, and that's gonna run a couple hundred even used. Then you have to decide if you're going to use the worn out tie rod ends that came with it, or spring for better ones, and that's not cheap either. Depending on what rear axle you have, you'll want to look at a set of wheel spacers so you match track width, that's gonna run you at least $50, and you'd better budget another chunk of change for odds and ends like fourwd1 says... you'd have to be gifted a lot of things to get out under $400, and that's assuming that you have access to the skills and tools needed for the fab work. $200 is insanely optimistic.
The only parts you'd be able to get used would be the axle, and springs and shackle. The going price for a used 79-85 axle around here is $250 or so. Used stock springs go for maybe $50.
If you went with stock springs instead of lifted you could get away with using the stock steering and save $400 there, but you'd have to pay a few bucks for the steering box.
You'd still have to buy a hanger kit unless you can fab your own.
im just gonna rip out the whole suspension out of a 85 yota and fabricate it to fit mine. my grandpa is a mechanic and has a shop with scrap metal and all the know how.
Don't forget your front drive shaft you will have to make, and adapting a double cardin joint to your rear drive shaft. and your new drive shafts will probably rub on your factory cross member and your fuel tank. have to do some retro fit work on your brakes. its a big job.
Make sure you get a professional welder to help you. Yes, you can probably practice and do it properly but it's not worth dieing, or killing someone else with a broken weld to save a few bucks. I do a lot of fab work on my truck but I had the SAS work done professionally. Also, in some areas, you might need to prove you had the work done by a certified welder.
Jesse1
