Savage skid plates
99Steve
I just got the 2 piece skids, my truck didn't have one. It does have the diff drop. I was reading that the rear skid plate needs spacers. Does anyone know how thick they need to be?
According to their website no mod is needed for 1" diff drop
Ships FREE to the lower 48 states. Please contact us for shipping to Alaska, Canada & Hawaii.
Our skid plates are made from 3/16" steel and are incredibly strong. Designed to protect the bottom of your 4Runner from damage from rocks and brush. 2 piece design makes the individual panels easy to remove for servicing your engine.
Application:
96-02 4Runner
Features:
Front plate has been redesigned to protect your lower a-arm mounts.
Laser cut and CNC formed.
Made from 3/16" hot rolled steel.
100% bolt on. No welding or drilling required.
Two-piece engine kit is designed for easy access to oil filter and drain plug.
Recessed slots for bolt heads reduce the chance of bolt damage on rocks.
Specifically designed to reduce heat build-up in transmission and transfer case from catalytic converter and engine.
Works with 1" differential drop kits without modification
Newly redesigned model to protect your lower a-arm mounts.
Includes:
Front Kit covers engine and includes two piece skid plate, and all hardware. Front kit replaces the factory skid plates and use many of the same bolt holes.
These are "build to order" so check the homepage for our current leadtime.
Installation Instructions
It says you "may need spacers" if you have the diff drop. How about try it and see if it fits. If it doesnt, get a washer or two to fill in the extra space.
But the install instructions say you may need to use the spacers that came with the diff drop kit on the back two bolts.
http://www.savageoffroad.biz/assets/images/SkidPlate2012/Skid Plates Installation.pdf
I was able to pull this from the Wayback Machine - for those looking:
https://web.archive.org/web/2018101...es/SkidPlate2012/Skid Plates Installation.pdf
However, I'm looking for how to mount the fuel tank skid - anyone have that link?
Edit - Savage never made one and it was hard for me to learn I don't actually have a fuel tank skid, as that is the one I'd want the most.
