Seat cushion removal question
vicar
Member
I see lots threads on taking the front seats completely out, but is there a way to remove the bottom seat cushion of the driver seat without taking the whole seat out of he truck?
Also some threads on taking the seats all the way out make it sound the seats are welded to the cross member; others make it sound like they can just be unbolted. Which is correct?
I have a 99 4Runner Limited (power seats).
I see lots threads on taking the front seats completely out, but is there a way to remove the bottom seat cushion of the driver seat without taking the whole seat out of the truck?
I removed my seats this past winter to put seat heaters in. To answer your question simply: No you cannot remove the seat cushion without removing the seat entire seat from the vehicle. Here's why. There are four bolts, one one each corner that hold the cushion frame to the rest of the frame. The plastic side panel cover the sides of the seat, where those bolts are located. The seat adjuster controls need to be removed to get to the plastic panels. There are 2 electrical plugs that need to be disconnected, but first recline the seat about half way back (this will line up the access of the seat back with the two rear bolts holding the cushion. Also, of course, the four bolts holding the whole thing to the floor.
Follow these steps:
Recline the seat halfway back.
Locate the bolts caps on the floor and remove them.
Remove bolts holding the seat to the floor
Tip the seat back, disconnect electrical plugs
Remove seat from vehicle
A camera to remember how it all goes back together is helpful
Remove adjuster controls, GENTLY pry them loose.
There is a screw on the back end of the plastic side covers, remove them
Pull the top edge of the plastic cover back to see where it attaches to the seat frame. GENTLY work from back to the front. The most forward clip requires you to slide it forward to free it from the frame, GENTLY
Loosen the wiring from the clips on the bottom of the cushion
Locate the four bolts on the four corners. Remove them.
This is from memory. I may be missing a couple of screws and such. Just be gentle when removing the plastic parts.
Check that all screws have been removed before you go yanking on anything. Just remember how expensive some parts can be if you feel the urge to be impatient!
It fairly intuitive and straight forward. If the holes for the back bolts are not aligned, carry the seat over to your vehicle, plug the two connectors back in, and recline it one way or the other until they do line up. Easy Peasy!
Thanks guys
Are the nuts welded underneath? How many? The front left bolt is pretty rusty and I'm concerned if I take the seat out I might have trouble getting it back in. I'm not a welder. Should I take it out and hope for the best? It does like some guys have had trouble with the nuts under the cross member breaking off. I really want to avoid that. But I also need to do some seat repair so I guess I have take my chances....
Thanks guys
Are you referring to the 4 bolts that hold the seat down? I remember a couple of those bolts being rusty on my dad's 4R. If you can get it to move, take it slow and spray some PB Blaster down in there. Work it back and forth and hopefully it'll free up enough to safely get it out. We ran a tap in the front 2 holes just to further clean things up before reinstalling with a little antisieze.
I had both seats out of my 2000 with power leather in about 10-15 minutes. 4 bolts and 1 electrical connection each. If I remember correctly, one bolt on each seat was a little difficult with rust but those are very hardy bolts. They will come out. The bolt covers just need to be pushed down or back depending on how they're clipped in. Don't force them or you'll break the little "hooks" holding them in.
For anyone removing the plastic side shield on a 1996–2002 4Runner manual seat:
After removing the adjustment wheel and any retaining screws, don't pry the shield straight outward.
The opening around the adjustment-wheel shaft has a notch that allows the shield to disengage from its retaining point.
Slide the entire plastic shield forward to release it. Once it clears the retaining point, the shield can be removed without forcing or breaking the plastic.
I've attached a photo showing the notched opening.
Thundro
