Seatbelt warning light backwards ??
Baja
Yep, I have no warning light until I buckle the seatbelt. Then it flashes, it is the drivers side. Any Ideas ? THX
Talked to my Toyota dealer "never seen that problem" bring it in and we will trouble shoot for $250.00. Any ideas where to start, I pulled seat and unplugged what I thought was the seat switch, no help.
Did you check your warranty guide to see if that is still covered under warranty? I remember the older Hondas/Toyotas covering seat belts for life (normal wear and tear included, not abuse and/or tampering). I noticed that my 12' is now only covered for ten years, but even if it was ten years your '05 should still be covered. I would look into seeing if you can get it covered under warranty since it is some what safety related. I mean technically, your 4runner is telling you to not wear your seat belt right??? :)
Did you try putting the seat belt from the passenger seat into the driver's receptacle? See if that keeps the light out?
I have heard of buckles failing and triggering SRS lights on Hondas before. I suspect the technology in Toyotas are not that much different.
Jhunt
