Secondary Air Injection Pump Failure on V8's! Important!
Thanks guys,
Folks are welcome to remove their entire intake manifold system and replace the pump, valves etc. This is typically more than most folks want to tackle when there is a EASY fix for a system that will only fail again.
I chose to bypass as it is more reliable and "permanant" fix compared to replacing the other component.
10mins and $50 vs 4-5 hours and $1,000+
Bypass is clear choice for most folks.
Hell I'd tell the recent guy that replaced everything to STILL do the bypass:)
After 2 years, still rocking your bypass system! Thanks again!!
Thanks guys,
Thanks guys,
hey sly,
I just found out about this thread after I had my truck throw on the code P2445 this morning. I see different codes being mentioned around this issue (P1445,P2440 etc.) on this thread and on other forums. Do you think the bypass kit would help me with 2445? It reads as secondary pump being jammed and the shop quoted $800 to replace the pump and module. I'd like to not spend that if I can.
Thanks!
edit: I just found this video and these codes all seem related to the same thing..
https://www.youtube.com/watch?v=rWMmgiCbXPA&t=77s&ab_channel=RuTechSolutions
hey sly,
Thanks!
P1441, P1442, P1444, P1445, P2440 - P2445-P2447 Toyota 4.7L, 5.7L AIP bypass and plate locations - YouTube
Yeah, 2445 easily defeated by bypass.
Glad to see this Thread has been useful for so many. Almost 8 years with this kit installed and since I made this thread, never an issue.
[MENTION=8828]slyfox75[/MENTION] Keep it up
Aaaand.....my 2006 secondary AIP just grenaded and threw bits and pieces downstream. $2600 to fix. Glad my other two 4Runner's are a 2003 and 2004.
With respect to the bypass kits, are they very easily removable and replaceable for the biannual smog inspections we have here in LA County, Commiefornia?
Ouch. So you had been running without a bypass kit I assume?
To answer your question, Yes. I bet you'd pass a visual with them installed.
There are videos online on the Slyfox and other companies install kits if you want to check it out before committing.
If you did a clean job and taped/tucked all the wiring, you will pass smog no problem.
I have had the Slyfox kit in for several years and have had a smog check In SoCal without any issues. You don't need to remove it.
AWESOME good to know, I paid the premium for the RuTech solution as I didn't mind paying an extra $100 premium for complete OEM looking device and ease of install. I don't think ANY smog tech will be able to tell this is not an OEM part unless they are intimate with this Mod and engine.
kit is awesome, so glad to have found this solution..
I didnt go out of my way to hide things per se, pushed and ziptied to back wall of the engine compartment, you can see there is a wire there though, its not hidden behind anything and you can see it routed to the cable coming out of MAF.. tucked the wires into the original sleeve and everything but its clearly not a "OEM" job
you think thats an issue?
I fired up my 4runner this morning and heard a vacuum for the first time. It went away after 10 seconds or so. No CEL no loss of power. I have read the first few pages and last few pages of this thread. It seems like I have caught the problem early but I do want to address this. It's a 2008 V8 4Runner with ~150k miles. I am looking for a plug and play solution if at all possible. Many of the early thread links to tundrasolutions are broken. I googled v8 4runner secondary air injection bypass and landed on hewitt tech, rutech, and slyfox pages to learn more.
Hewitt tech confused me more with various add-ons and generations. It looks like it also needs a signal from the starter relay. Their customer service indicated that I start with a Gen1 module and might need a pump proxy or pressure addon in the future, assuming I don't need emissions testing (I am in Mass; there is no tailpipe testing however I am not sure if the OBD plug could be an issue). If emissions is required they indicated I would need a Gen2 system.
Rutech looks to be pure plug and play, but no starter relay signal.
Slyfox looks to require cutting and splicing some wires but is by far the most economical.
There are no mentions of pump proxies or pressure modules from either rutech or slyfox as far as i can see.
Can I ask the fine folks here to guide me on what makes the most sense?
Go with [MENTION=8828]slyfox75[/MENTION] , as you mentioned his is the most economical, he includes very easy to follow instructions and if I'm not mistaken he will also help by phone if necessary, and I have never heard of anyone not being satisfied and his seems to work every time.
Not so with the other two you have mentioned, I have read of others having issues on both of those from time to time,
I have "mentioned" slyfox above in my reply so he should be notified see this and give you some input from his end.
Yep, Im here to help as needed. Reach out and we can discuss. But if you don't have codes yet.....YOU WILL. The systems get more and more problematic until you have bigger issues. The sooner the bypass is in place the better off you will be.
I've had the slyfox kit installed in my '08 now for over a year, and out of the blue now I'm getting a P011B error code, which of course makes the dash light up with traction and VSC lights.
I believe it's throwing the error, due to the difference between the IAT and the coolant temperature. Weird though it hasn't caused me any issues for over an year now.
Any thoughts, I know there was discussion on '08's potentially having differences in the ECU or hardware.
Hi all,
I read the first couple of pages, then realized it started 2014 so I skipped to the last page.
A little googling and I found this:
"This affects the 2005-2009 Toyota Tundra iForce V8 models."
Is this generally understood to be accurate ? Taking into account of course that it affects other vehicles with the same engine. (Or maybe that is the actual name of the engine?) I wonder if there aren't any land cruisers, vans, etc., that had the same engine ?
Anyway, I just want to make sure to avoid any models with badness in them ! ! ! !
Loud Vacuum Cleaner Noise on Cold Start : Toyota Tundra Exhaust and Emissions
:artist2:
The code you have wouldn't have anything to do with the air pump bypass you installed.
You either have a faulty temperature sensor/s, or an issue with the wiring to either sensor.
P011B Engine Coolant Temperature/Intake Air Temperature Correlation
If your temperature gauge seems to be working as it should I would start with checking the intake air (IAT) sensor as my first choice.
Thanks for your reply. It was my understanding that the bypass kit tricks the ECU into thinking the temperature is higher than it actually is, to prevent the air pump from actually running. I think the computer was unhappy of the difference between the IAT's and the coolant temps.
I have cleared the code manually, and will continue to monitor.
I'm going to mention [MENTION=8828]slyfox75[/MENTION] so he can have some input into your issue!
alexaturner
