separate hub from rotor
goatfarmer
90 4Runner 4x4: Replacing front brake and suspension components, removed the hub and found the rotor will need to be replaced. The 6 bolts that hold them together have been removed, without using excessive force I tried using a pry bar with no luck. I thought before resorting to 'big bertha' my 16 lb sledge hammer, and possibily damaging the hub I best check and ask if any member(s) are familiar and can advise whether I missed a step, and/or, is the rotor pressed onto the hub. Any input, suggestions appreciated.
It's not pressed, it just has 20+ years of stuck on it! Spray it down with some WD-40 or whatever penetrating oil you have and let it sit for a few minutes. Then beat on it a bit with a heavy rubber mallet or a dead blow hammer. If that doesn't work you can put it in a vise on the rotor side and use a pry bar in-between the two evenly on both sides.
Appreciate the info, went and gave both hubs/rotors a good dose of Sili Kroil and I'll let them set over night.
You're not going to hurt that hub. Get a friend to hold a large cold chisel, and give it a couple friendly taps with that 16lb persuader of yours.
Used the pry bar and worked it around the hub and with very little effort they separated.
thdancing-chicken1.gif~original
Appreciate the help from all, thank you!!
Before you reassemble the new rotors on the hub, use a wire brush or some coarse grit sand paper and clean the hub a little to make them easier to reassemble and disassemble again in the future.
Used 'Marine Klean'; love the stuff, and scrubbed the hub thoroughly with a stiff wire brush before installing the rotor, boths sides slipped right on with no problem. Thanks for the headsup though.
smoke1.gif~original
