Sheared Lug Nut Bolt
cgarrett5119
One of my lug nut bolts sheared off today... Didn't think that would be possible but then again I have seen stranger things. What's the fix for this?
it depends on whether it was the front or the rear. If it is the rear you need to pull the axle shaft out and press in a new stud, not that hard... if it was the front, you will need to try to get the stud out of the wheel unit bearing. Usually if you havent replaced the unit bearing for a good while, 60K or so miles you could just replace it and it would have all new studs and bearings. I did this on my jeep wrangler, rather than try to take apart the unit bearing.
A shop might charge you a couple hundred to replace it but it can be done if you have a HF press (10ton). on the rear axle if you cant get it pressed out you might have to take it to a shop if they are too long or stuck too hard.
I recently did this on mine. Was on the rear, was a bit of a pain but only took about an hour. I got my new studs at Kragen or whatever its called now. $10 if i remember right.
Did you have to use a press? What was your process? Thanks.
no i just put a nut on the end and hit it with a big hammer and it came off. May want to use some wd-40 or so on rusty applications. Then push it through and torque the lug down with the nut and itll pull it through.
charlesz
