Sherpa Equipment Company Rack Systems
will you have multiple options for the drawers? i like what you have now, but possibly a wider/longer one that i can sleep on top of?
Yep, can see the mountains from WI :rockon:
<a data-flickr-embed="true" href="https://www.flickr.com/photos/185141496@N07/49013169286/in/album-72157711510133311/" title="1104190632d"><img src="https://live.staticflickr.com/65535/49013169286_7c64f8d97b_b.jpg" width="1024" height="576" alt="1104190632d"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
Sherpa Equipment Co. will be running a Black Friday sale from November 20 through December 2nd.
10% off all Rack Systems
15% off all Drawer Systems
20% off all Sherpa Accessories
sales?
Dam the Halloween sale was better than the Black Friday Sale?? Funds werent available over halloween, figured Id get the same or hopefully a better deal with the grand daddy of all sales on Black Friday. Guess Ill have to wait to next halloween.:drama:
Depending on what you are buying this sale can actually net you a lot more savings.
what is a 'fairing'? it may be helpful to add this info to your site for idiots like me.
It is the front piece of the rack over the windshield designed to deflect the wind over the rack and minimize and wind noise. Full is for no lightbar, half allows for the use of a single row lightbar.
thank you. i am new to racks, but hot damn does your half rack for the 3rd gen look good. when im in the market i will seriously consider.
The Sherpa Equipment Co. PAK System
These aluminum framed drawers are built from the ground up with the true adventurist in mind. Each drawer module is built from baltic birch and the exterior is lined with HDPE. This provides a strong and durable exterior surface designed to handle whatever you throw at it while still being easy to clean. Our drawer system retains access to the extrusion slots for quick and easy mounting for a variety of accessories and transfers the capabilities of our racks to the back of your rig. Available in both a stackable or long variant to fit your adventure needs.
Each drawer unit is designed to be hard-mounted into our Sherpa Baseplate System but can be mounted w/ another method of your choosing.
Sherpa Base Plate System
MOUNTING
— Each drawer unit is designed to be both hard mounted with our Sherpa Baseplate System or mounted by a method of your choosing.
HDPE — High Density Polyethylene is a high density polymer often used in cutting boards. This surface is rugged, UV & stain resistant, and cleans easily.
DRAWER ASSEMBLY — Each drawer unit comes pre-assembled and packaged individually.
BASEPLATE INSTALLATION
— Baseplate installation requires removing the existing 4 tie-downs in the cargo area.
PRODUCT EXTERIOR SPECS:
STACKABLE: 33.25” x 19.5” x 10.25”
LONG: 38.25” x 19.5” x 10.25”
WEIGHT: 58.4lbs*
WEIGHT: 64lbs*
*Per Drawer Unit
PRODUCT INTERIOR SPECS:
DRAWER LOAD RATING: 200lbs
DRAWER SLIDE RATING:
500lbs
STACKABLE DIMENSIONS:
31” x 14.5” x 7.25”
LONG DIMENSIONS: 36” x 14.5” x 7.25”​
rack info
Quick question, is there a reason your gen 3 rack uses the OEM factory track vs removing the track and using the track mounting points? Wouldnt it be a more secure attachment point?
thanks
thanks
Absolutely not, the roof track is the only thing providing any rigidity to the already weak 3rd gen roof. Some people even go as far as reinforcing the roof from the underside if they plan to really loud serious weight on their roof.
Ah, thanks for the clarification. Any idea when youll have a sale on racks like the Halloween one?
thanks
Been lusting over the gear on your site and te budget is growing in your direction! I have a question about your 3rd gen baseplate. When it says, "the carpet must be removed" Are you referring to the "semi-glued down carpet with the insulation touching the frame" carpet or easily removable carpet pieces that came with my 99 Limited? And if I chose longer bolts for the connection points (allowing for the stock carpet), is there an issue that you have discovered? Thanks for your time.
Appreciate it, man!
The 3rd gen requires removal of the carpet mat but not the actual carpet. I think you may have misread on the website or may have been looking at the 4th gen which does require removing the actual carpet.
Hopefully, this clears everything up.
