Show us your rack!
x2 on Perkin Performance's quality. Like SeattleMike, I too considered the gobi but after talking with Jason and seeing his work I decided to have him build me one to fit my needs.
X3 on Perkin's Performance...and also credit to darkie3495 for designing it.
Perkins Performance roof rack with a Rigid Industries 40" E-Series LED light bar and adjustable cross bars.
P1020445.jpg~original
P1000784.jpg~original
P1040137.jpg~original
P1040185.jpg~original
P1000789.jpg~original
I cut down my Kargo Master "Safari" rack to fit better. It was too wide and just didn't look right even after I flipped the top cage around. They are made for a Jeep and are 52" W x 60" L, which doesn't fit the 3rd Gen at all.
I also remounted it using the mounts that came with it, by reusing the factory rail "nuts". Way better than mounting it to the factory cross bars which didn't look good at all.
I cut the base down 6" on each side and cut 10" out of the center. I bolted the top cage back together and now it fits just right.
Stock size:
Dreary day at the beach by CENTCOM_Survivor, on Flickr
Rear view of rack by CENTCOM_Survivor, on Flickr
Old mounting:
Old rack mounting by CENTCOM_Survivor, on Flickr
Cut down:
Cutting the rack by CENTCOM_Survivor, on Flickr
10" out of the centers by CENTCOM_Survivor, on Flickr
Rack cuts by CENTCOM_Survivor, on Flickr
Beach by CENTCOM_Survivor, on Flickr
Rack close up by CENTCOM_Survivor, on Flickr
New mounts:
Rack mounting by CENTCOM_Survivor, on Flickr
Safari rack Cut down and welded to mounts and then rivnuted the roof and installed the rack. Paid 125 after materials to install and help welding it together.
Just mounted a basket yesterday to my oem crossbars. I was told by a guy that they aren't very strong. My basket it only 20# and I figure I'll basically only have my deflated pontoon boat (45#ish) up there. These should be able to support up to 100# though, no?
thoughts?
It's only something I'll have on for camping which is only a couple times a year maybe a week or two at a time.
thanks,
thoughts?
thanks,
I read somewhere that they are rated for 130-165# depending on the generation. You should be fine.
thoughts?
thanks,
Kakuno, this is a bit difficult to answer not knowing the manufacturer of the basket. I've had a few different baskets, and not one had less than a 160lb weight capacity (evenly distributed). The one I currently use is a Gobi and the weight cap is in excess of 300lbs. I would check any/all labeling on your rack for some indication. If not available, my next route would be determining the manufacturer and then checking their site for your model, or contacting them direct. My personal opinion, you should be okay with what you're expecting to carry, but better to be safe and confirm.
The basket is rated for 250# but my concern was the oem cross braces. I should have specified.
Thank you for the response.
Whitson all the way
Rocking the now elusive and rare Whitson Metalworks full length rack. . .thanks a lot Gobi.
How are the Rolas holding up? Checked them out on amazon and there were a lot of reviews of rust.
This is my second rack for a different truck of course. I used black gasket sealer when joining them and I haven't had any rust problems at all.
Good luck.
300_5669_zps4e2e40ef.jpg~original
Yakima Megawarrior with extension
Mounted a Yakima Megawarrior with extension this weekend. I tweaked the included mounting hardware and bolted it to my rails, bypassing the weak factory crossbars.
Those reviews would be accurate... As long as you refinish/treat the rack somewhat regularly, they should be fine. Also, it is probably better to leave it in the garage until you need it for a trail run or camping trip. It makes having it a bit more of a PIA. But, it will last a lot longer...
Hope this helps
seltzernator
