Shrockworks bumper lighting
cnpellegrino
So I got my Shrockworks front bumper mounted up but now I have to do the lighting. Is there anyway I can buy an adapter to use so I can wire the signals that came with the bumper to the factory harness? I'd really like to avoid cutting the factory harness if possible.
Just cut the aftermarket turn signal wires and connect the turn signal side of the stock connectors. It's not that hard!
I don't understand. I have the factory connector coming from the truck and just wires coming off the lights. Just looking for an end I can attach to the aftermarket stuff to make it plug and play with the factory stuff.
So, you are uncomfortable modifying the wiring harness, but you are fine cutting/modifying the frame of the truck? ;):
If you plan on being able to return the truck to stock, leave enough length on the pigtail you cut off to repair the harness. You could put on some Deutsch connectors on there if you want to have a plug there, but it is also pretty easy to just remove the bulb if/when you want to remove the bumper at some point (for installing a winch, or whatever).
If you use switchback LEDs and wire it up right, you can have a nice turn signal setup like this:
YouTube
-Charlie
Ah, I forgot the stock turns don't have connectors before the bulbs.
Just buy a couple of these connectors (link) and cut your stock wires leaving as much length as possible. You can always re-wire into your OEM bulb if you change your mind later.
2001ATL
