skid plate removal
I am definitely missing the second one from the front.
Anybody have a pic handy to make my junkyard quest easier?
This is the best I have:
3F5F7B02-D653-4277-956B-0A08CED0B124_zpsoaq0wk7i.jpg~original
-Charlie
Here are mine off the truck getting ready to be prepped and POR-15'd:
7gnNRdORRn7Js5W80USYA1w1AKlCEdeUXPBdrEngttKrToZUztTn_MSW8t40sadcf7FQj9OCCJfpKI3bkR0jAylbvFWvRoyc89TkQuQo-fEyj8NQ6H92M-d6K9pA3OprdPVF_NVWTGcopkDLEGJJ9zXxDRJ1Z7RQ4IzP9KEpTYw3-ZpmYTVgqJH8JEsKvkg9GVwpJaD4UKvLCgnth9Gzi9RxU14d4WHYwiFkOw3rOx0KSsvjlCmyMVfhNtb4D9PB6PSC_P4ADEqYrQqYzh5zvC2yJpYSY31cPpPAgpv_2JhBu5E4yMbxLrcoTVYkQRL6EH7MBWGBlOZsDtxJDu2a0cJlLXSjfOrFLjOy0fAQy62NUpr2x3bhGk-aaMNaq2aeRkOFZwFMEXFzIJrhuyGI8J2_jTXkWIpkDuvI4YnOZlCant4PYTz_Q0UuRfameyN3RDkq28vA3rM4YJbCTUpoLRcr0oQX7DaR3-BC6ew-RtM7kPaflyCBEUfMdUtfUkilJAhW9NlcwCJUoDj4V6QLnD-p3KLjPTNs5E_0jcDg8NXi36SUpMyIz2z3q4pVwDPG-uzjOQoafoaWRR_Wv6LvigKJYHZdar5WOORC9glKFtv0Km-GAmN3V1v6Ar4404lDsPGiV7ZZw453ovzyy2CP8X0W1uGBuszWod7lc8Wn7g=w800-h600-no
Front is on the right.
My 96 had two. If given the choice of only having one, I'd take the front one because of the radiator protection. See [MENTION=151090]MudMud[/MENTION] post.
[MENTION=156409]andyo[/MENTION] - I don't really care for driving without the plate because the radiator hangs a bit below the frame and I'd hate for a rock to go through it just because I didn't put the plate on.
[MENTION=151090]MudMud[/MENTION] That was my concern. I'm going to try and get the sheared bolts drilled out and replace them. Hopefully I don't run into any of the factory cross-threading issues I've read about.
If they haven't been off or you think there might be rust, hit the heads with a propane torch to break some of the corrotion. Use some common sense with the torch and go easy on the bolts. I broke 4 of the 7 on my Tacoma and luckily only had to drill one of them out. On the Tacoma the bracket that holds the front bolts near the radiator is reverse to the 4runner so the ends of the bolts were visible and as far as I can tell this is not the case with 4runners (I haven't taken them off my 4runner yet). Was a pain in the butt getting it all back together but it could have been much much worse.
Hi! I’m trying to take off my front skid plate on my ‘13 SR5 so I can clean it. Would it be the same as the others? Thanks!
Mike Sargent
