SmittyBuilt XRC Winch Improvement Write Up
Dous
Anyone who has an XRC winch by Smittybuilt will tell you they are of decent quality, minus a few things
-Hard to free spool
-Solenoids suck
-Slow line speed
What this write up will fix is the first two things, unfortunately the third is something you will have to live with :cry:
Part 1
The first thing we will address is the free spooling issue, which is a result of the grease. As we know these are made in China, and they chose the cheapest grease, read glue, I have ever seen. This stuff was insanely tacky, but I am assuming the winch will be fine with less tacky grease, I did a pull with mine and it seemed fine after the re-greasing.
To start off:
Gather your supplies:
- At least 2 rolls of good paper towels
-Mineral Spirits
-Good quality grease, only need one tub
-Old toothbrush
-Bucket
-Brake Cleaner
IMG_0698.jpg~original
Dismount your winch from the mounting surface and bring it to a bench to work on it, this is will be a very messy process and is not possible with the winch still on the car
IMG_0682.jpg~original
Next loosen all of the allen bolts holding on the gear cover, these are small so be careful not to lose them
IMG_0685.jpg~original
Here is what you should have now, all the bolts, and the PAPER gasket between the gear cover and mating surface. If you are careful you can reuse this gasket, otherwise you will just use RTV to seal it.
IMG_0688.jpg~original
Now this is what you should see inside the winch
IMG_0687.jpg~original
Grab ahold of the gear assembly and wiggle is out, not very hard to do. The grease holds most of it together. It should all pull out as one unit, minus the thrid planetary gear set. You can then reach in and pull the remaining gear set out.
IMG_0692.jpg~original
Uh...yea
IMG_0689.jpg~original
Forgive me here, because the picture taking slowed down, it gets REALLY messy.
Here are the gears separated and cleaned.
IMG_0699.jpg~original
The best way I found to remove this grease is with mineral spirits.
-Pour mineral spirits in a small bucket
-Put gear in bucket
-Scrub with old tooth brush.
It is a good method and gets them pretty darn clean. I didn't bother with completely disassembling each individual planetary gear set, but if you are really worried about getting all of that crappy grease out that is the best way to do it.
Also very important. When you are cleaning it you will have noticed these two plastic washers. These go between the second and third set of planetary gears, they will remain in place until you start cleaning. The grease holds them on pretty good
IMG_0700.jpg~original
To clean the inside of the winch, I used brake cleaner. It dissolves the grease and with the help of a brush and some paper towels you can get the majority of it removed.
IMG_0701.jpg~original
NOW....repack the gears with grease, very easy to do and then reassemble. The photos of the clean gear set show which way they go in, but if for some reason you get confused this is really good reference.
XRC8 Free-spool Fix - JeepForum.com
Once the gears are greased and back in place put the cover back on with the paper gasket, or RTV. Also make sure to put some grease on the clutch lever, you can see where is should go when you look at the cover, it makes it quite a bit easier to engage and disengage.
Part 2
Next we will be fixing the solenoid. The problem is that the crappy rubber gasket in the solenoid lets water get in, which is not a good thing. Replacing this gasket with RTV will solve any water getting in.
What you will need:
RTV or some type of sealant
Dielectric Grease
IMG_0705.jpg~original
Here is the solenoid with the plastic cover removed.
IMG_0702.jpg~original
Remove the four allen bolts holding it together.
[imghttp://i230.photobucket.com/albums/ee259/Dous07/IMG_0706.jpg[/img]
Separate the two halves, you will see these 4 springs, they are hold in place, but can fall out pretty easily so keep an eye on them
IMG_0709.jpg~original
Here you can see the seal, it is not very good, also you can review the benefits of nitrile over latex.
IMG_0710.jpg~original
Apply your RTV in the groove of the surface and mate them together. Easy.
IMG_0712.jpg~original
Here you can see where I put some RTV on the outside of the solenoid where the wire enters. I am assuming this is where water is getting in normally, I wanted as much water resistance as possible
IMG_0714.jpg~original
Next I put dielectric grease over all the connections to prevent future corrosion.
IMG_0717.jpg~original
Put it all back together and you are done!
You CAN polish a t.urd
IMG_0718.jpg~original
All buttoned up
IMG_0719.jpg~original
In review
After testing the winch free spools SO much easier, it used to take two people to free spool the thing. Now I can literally grab the thimble with my pinky and free spool it. It is also quieter during operation, but in nature this is a noisy winch. Also by waterproofing the solenoid I won't have to worry about it failing on me, like it has to so many other people.
Great write-up. Keep in mind that while waterproofing is good it's also trapping heat from escaping. I wouldn't waterproof it anymore than what the factory does honestly. Great job though. That's one nice polished t.urd now :D
Haha thanks. Yea I have seen where people argue that the RTV will KEEP water in, but I have seen too many fail due to corrosion with the factory gasket. My solenoid still looked good, but the winch is still only a few months old. In terms of the heat, I don't think the RTV will keep any more in than the gasket did.
Honestly the gasket appeared to be doing a good job, but I think it deteriorates quickly.
Great write up! I guess I'll need to take both of mine out and do this stuff. Any idea if these things are a problem with the XRC10, or just the XRC8?
Thanks! It's a problem with all of the XRC series. They use the same cheap grease in all of them.
I am sure the solenoid has the same gasket, not hard to take it apart and see. If you have corrosion inside the solenoid then I would seal it up good. If it looks fine, then that will be a personal decision.
:D
I'll have to take a second look at the solenoid situation...mine is what you might call, custom mounted! WyoRunner and I took the whole thing apart, cut the red plate and mounted it under the headlight and put the remote connector in the grill. Its not inside the box at all anymore. Probably not very protected....but so far it hasn't given me any issues either!
**Pics of the mount included! Sorry they're so big.
Haha, well I don't think the box does much if anything. Easy to get to anyway, well maybe not with the bumper
I can get to it from underneath if I need to...even disconnect it pretty easily from under there actually. Getting the winch out is another whole project though!
utkrstam
