smkd13's Build Thread
Extra!!! Extra!!! Read all about it!!!
So finally making a update for this build thread I have been super lax on lately. Between work, and the severe amount of “modification trips” to Idaho I have been making I haven’t had the time to sit down and update anything. But here we go, where to start, where to start????
Ok so sliders it is! Back at the end of April I finally got my sliders. Made my mandatory trip to ID to install them as I have access to two full shops up there. One is a auto shop and the other is basically a fab shop for the most part. As I am anal about everything and like to do all my own work, welding included, I go there. But on to some pictures:
Mounted up and grip taped (grip tape is from home depot, 2” wide, $15, only one roll needed):
IMG_0543_zps4b70c97a.jpg~original
IMG_0544_zps90803472.jpg~original
IMG_0564_zps3d49bfa5.jpg~original
IMG_0565_zpsc38d120c.jpg~original
Here is what my welding looks like not the best but decent:
IMG_0547_zps92afaa22.jpg~original
IMG_0545_zps64866845.jpg~original
Here is a better example of it (done on my buddies frame that we had to patch, mine was the vertical weld in the corner):
IMG_3219_zps87d8ad23.jpg~original
I got my new bump stops installed (yes I fab’d the spacers myself):
IMG_0548_zps55f7198a.jpg~original
Uniden Pro520XL is installed w/ 5’ FS and Wilson Coax (SWR = 1.1 on 1 and 40):
IMG_0562_zps0b7f4871.jpg~original
Got my Blue Sea Aux Box installed (40 amp maxi fuse soon to be breaker):
IMG_0563_zps7f9fc778.jpg~original
Gave the good old girl a treat with some AmsOil and OEM filter of course:
IMG_3208_zpsf0a5db2f.jpg~original
IMG_3207_zps474059d2.jpg~original
And because I am a cheap ass and don’t see a point to extended brake cables I welded the mounts higher up and bent the tabs, so no more strain on the brake lines at full droop and flex:
IMG_3209_zps1ef62704.jpg~original
I was having a rubbing issue on my rear bumper so I “clearance” it:
IMG_0560_zpsc9b7c0ed.jpg~original
IMG_0561_zpsb1e22cb0.jpg~original
IMG_0570_zpsdb8e5522.jpg~original
After “clearancing” of my bumper, my exhaust stuck our pretty bad so that had to be fixed and this was my best option. Clean and out of the way:
IMG_0549_zps761798f6.jpg~original
I also removed the fender flares as I lost one on the freeway so here you go:
IMG_0567_zps1007cf69.jpg~original
IMG_0566_zpsdac799f4.jpg~original
IMG_3204_zpsa4845020.jpg~original
IMG_3206_zps7430016d.jpg~original
Installed a Thrush Turbo exhaust. It give a little bit of a better sound and no drone, I actually want it to be a little louder though. As well, I am happy with it that it doesn’t hang down as far as the old one:
Finally lost a fender flare on the freeway (it was gonna happened), so those got removed. Gotta find someone with a welder that I can weld up the holes with (the one I have access to is to strong):
IMG_0550_zps0b2679da.jpg~original
IMG_0552_zpsc7b117c9.jpg~original
I also found out that I had a seized adjustment cam for my alignment. We messed up the bolt trying to break it free and so I tracked down a new one. Got two used ones, a lower control arm and a LBJ for 32 bucks from the salvage yard (trail spare):
IMG_3214_zps8507b8ee.jpg~original
My buddy actually had a set of LCAs with new bushings in them that he wasn’t using from his Taco, so we compared them and they are the exact same as a 4Runner. The swaybar location is different but everything else is the same:
Out with the old:
IMG_3216_zps8dd256b4.jpg~original
In with the new:
IMG_3218_zpsf9fdd67f.jpg~original
And for all you who are wondering how much of a difference there is in Tacoma and 4Runner LBJs well here is your comparison, the lower stud is the same but the OTRE hole is obviously bigger on the Tacoma:
IMG_3211_zps9d2b8b3a.jpg~original
New OTREs finally:
IMG_0553_zps64bd71f4.jpg~original
And now the big one: Light Racing Upper Control Arms!!! After a decent discussion with my buddy we decided that Launch Controls are lower on the list than getting my front end suspension squared away so I returned them and got a the LRs. Install was straight forward and to the point. The only pain was getting the UBJs but nothing a hammer and big socket didn’t handle fine. Installed the slug adapter and set the arms for max camber and +2 caster. Here is the end result of the install (sorry no install picture this time):
IMG_0558_zpsd480aa6e.jpg~original
IMG_0559_zps7394b658.jpg~original
IMG_0555_zps7d93aea0.jpg~original
IMG_0556_zps1e786c58.jpg~original
IMG_0557_zps40cadeff.jpg~original
and at full droop here is where they are sitting. I love the clearance of the spring I have with these:
IMG_3212_zps1f753e92.jpg~original
Looking good Ben! Man you have been busy, everything looks like it came out great, Im not really a fan of our trucks without the flares but i understand they are expensive and hard to find if you lose one.
The LR ucas are great, i have had no trouble out of mine since installing them in January, it looks like you are at the "D" position for the adjustment up top. You say you set them at max camber, so yours are slid as far outboard as possible? Wont that cause more wear on the outside shoulder lugs? What do your alignment numbers look like?
Nathan
seltzernator
