Ok well here is the write up for the kick panel lights:
What you will need:
~18ga wire Black and Red
~LED of choice (I used these:
Little Dot SMD LED)
~Soldering Tools
~Shrink Wrap
~Torch
Basically a good place to start is by getting the switches ready. The switches have a rubber cover on them. There are two bumps, the top one is the button switch and the lower one is the bolt that grounds the switch.
(This is a Ground Interrupt Switch which means that it interrupts the flow of current. This is better because it keeps a potential energy on the load. When the switch makes a connection, because the load already has a potential, this eliminates a current spike.)
Removed the bolt. Then you removed the trim that is on the direct other side of the B pillar. There is a switch there with a small black wire connecting to the larger red wire. Here is what the switches look like.
You have two options. You can either solder to the switch like i chose to do or you can solder to the small black wire. As i did not want to mess with the harness on the car and soldering in the vehicle would suck, I chose the switch. I attached 6 ft of black 18ga wire to the switch.
After the solder cools, slide the shrink wrap on and heat so that it seals the new joint
Next is where it starts to gets more intensive. Remove the kick molding, the door jam molding, and the B pillar molding. Install the switch and route the wire in the channel along the door. Reinstall the bolt.
Next we need to remove the glove box (two screws on the bottom) and the panel under the steering wheel (4 bolts in each corner). I chose to place the LED in these locations (LEDs have sticky tape on the backs of them):
Then you route the wires towards the center console. I chose to run my wires to the central location as there are two sets of lights. I twisted the two black wires together and likewise for the red, then soldered and shrink wrapped them to a 1 ft length of corresponding color.
I pulled a constant positive from my Blue Sea aux box (this can be pulled from the 12V constant on you stereo as well,
these lights only pull 20mA). You have to have a constant positive as the lights need to come on when the key is not turned on. Run the wire from the power source to the center console. You will solder and shrink wrap the reds all together and the blacks all together.
I then tucked them all out of the way
If all done correctly you now should have something to this effect:
Hope this is helpful. I will make a thread about this so that it is easier to find it. It will be a little more intensive on pictures and explanation, as well some other wiring options that will make it more functional with the overhead dome light.
