Smoke coming from AC vents?
Not on the 4runner but I did have the same thing happen to me in my Bronco. It turned out that it was low on/losing freon due to a minute crack in the condenser. When I pulled the acc/drier, it almost crumbled in my hands. Maybe there were mice in there after all.
Charge it, and if that doesn't cure it, a dye test may be in your future.
Good luck.
Update: I switched it from Fresh Air to Recirculate today while on the road for work. No fog at all. A/C is colder too.
Mine does this as well. It's noticeably colder. This is the first car/truck I've ever had where it was that drastic of a difference.
junr
junr
You still installing your lift tomorrow? I have a few projects going on with my house right now so not sure if I can make it or not.
I am. Headed out to my friends place out past Valley Forge. We are starting at 7:30. We were going to use a lift but the person needs the lift to fix some heavy equipment.
If you want to join, give me a call later...I'll PM you my number. If you can't make it, no worries. Maybe I can call you in a panic when I get stuck :)
junr
This is an evaporator issue and what you are seeing is the chilled moisture. A previous poster is correct, there is a point at which the evaporator reaches a limit and can no longer pull all the moisture out of the air.
If this was a new car I would say have it checked, but you are fine. Older cars had smaller coils and evap systems and it didn't take much to over power them.
uthanacha
