Smoked something nasty while in 4-wheel drive
The question is whether your truck was equipped with it from the factory or not and if a diff was replaced at some point to the wrong ratio.
Most/all of the rear locker 4Runners are 4.3 ratio front/rear and most of the rest are 4.1 front/rear - so if either the front or the rear was replaced on its own, there could be problems.
There is no viscous coupler in the 3rd gen multi-mode transfer case. Later transfer cases did have a viscous coupler in some configurations. If you are feeling any binding in "AWD" mode (four green wheels lit, no center orange light), there is a problem with your 4WD system. Even on dry straight roads, you should feel no binding or odd behaviors in locked 4WD (orange light - you would feel it when turning and that should be avoided).
-Charlie
The locker is original equipment. It wasn't added later. This rig is stock. Canadian, but stock.
No viscous coupler... I'm both happy and sad about that. I've spent the last hour down a rabbit hole and imagining how I could replace the non-Newtonian fluid myself. Then again, those are expensive.
The binding is happening, but it was minutes and miles apart. I was on the freeway, as I mentioned. I could feel the steering getting stiffer and stiffer and then the 'pop' as it came free.
One thing I didn't mention. This journey started off with me stuck in my driveway. I live on an incline and couldn't get up the hill in 4wd. Naturally, the next thing I tried was the locker. I engaged the rear, but found it was causing too much lateral movement. I was sliding sideways instead of going backwards. So I unlocked the locker and put on chains. This got me out of my driveway and down the road. I removed the chains and started down the road as I first mentioned.
Now, I wonder if my locker never disengaged? I don't think I would feel that in my steering as I had, but it would definitely cause the binding.
Probably a long shot. I'm guessing I have a T-Case issue.
Actually, reading my own response above makes me wonder if I have a front differential issue and this has nothing to do with the transfer case. Could the front be locking somehow? I'm afraid to say that I'm clueless on this vehicle. I just never took the time to learn its components. Is the front diff limited slip, or does it have some other feature that may have failed?
If you were on the freeway and felt it, it is unlikely a 4WD issue. Or at least not a normal one. You couldn't turn quickly enough at highway speeds to get 4WD binding.
Try "AWD" mode in a parking lot and see if you have issues there, which should rule out a number of issues (it should drive just like 2WD). Then locked 4WD (center diff) in a straight line. It should still drive 'normal' even on dry pavement until you turn.
The 4WD system should be able to disengage no problems - sometimes when they aren't 'exercised' they get sticky/slow. Worst case for mine is needing to lift the throttle (though that's unfair, my transfer case is manual).
4WD binding would just lead to a bit of tire chirping and needing extra gas to make tight turns - no popping or similar should be felt.
-Charlie
The rear locker is standard equipment for this year. It's one of the reasons I chose this model. I'm fairly certain the ratios are correct, as this is a new issue for me. It has never done this binding up before when I push the button.
I see today that one of my front tires is pretty low. I don't think that would cause it, as the front diff obviously isn't locked, but I'm otherwise out of ideas.
There is one way to know for sure and will take 15 seconds of your time. On your doorjamb sticker, you'll see a gear code. If you've got A03A, it came with 4.10 gears from the factory. If it says anything else, it was built with 4.30 gears.
My 2000 has done the stinky front diff puke twice. Both times after an extended drive in AWD when it was in the 20s the night before, and still fairly cool out.
Only the '01 and '02 get the fancy pictogram with the green or orange lights regarding the state of the 4x4 system. The '99 and '00 guys have to suffer with only a rear locker.
The 99' LTD(Oct 98') + has the 4wd and 4x4 position indicator. I drive with 4wd or 4x4 quite a bit in the summer 90*F / 32*C on backroads for hours on end and at high speeds as well as winter for 6 months, never had a front diff puke oil out.
-Charlie
You are right, my mistake. I assumed the V in Toyota tcase nomenclature meant viscous coupling. It does - but only if the V is at the end. Multimode is a pure open diff.
Later t-cases have a gear type torsen center diff to counteract the open diff. Better than a viscous coupling. Only truck tcase I can think of with the viscous coupler then is in the FZJ80 and Prado 95.
You can enter your VIN into this Toyota website and see what equipment it had when new: Vehicle Specification | Toyota Owners
I don't think any models had standard rear lockers. But I could be wrong. I know they're more common on Limited models, but still far from common. And pretty rare on SR5 models.
My '99 is a factory manual locker, and it came with the #RARE 4.10 locker diff in the rear. Manual transmissions only came on 'lesser' models (mine is a Highlander package SR5), and lockers were a bit more rare on lesser models as well (where people were presumably watching that total price and not just checking option boxes with abandon), so it's a combination of two rare options on the same car.
My diff started making a whirring noise at around 215K miles, and armed with 'enough knowledge to be dangerous' I found another locking diff and swapped it in, since it was from the far more common automatic lockers, it was a 4.30. And I just assumed (bad idea) that since 'all lockers are 4.30' that mine was a 4.30 as well. Well... apparently 98% of all lockers are 4.30.
Anyhow, I did drive it for a couple of months with the 4.10 in front and the 4.30 in rear. And it really wasn't as bad as you'd think. It's a pretty small difference, and since mine is the SR5/manual trans, it doesn't have the AWD mode - so the only time you use 4WD is in a low traction situation, where the small difference in gearing wasn't enough to make an issue or make it obvious something was off. I did certainly get a bit more tire squawking than normal out in Utah going over bits of sandstone between the sand (like at Elephant Hill) - but barely any more than my wife's manual '96 was doing -with matching diffs. And I'd almost want to say that in some situations it actually worked BETTER - when turning tightly in 4WD the front wheels tend to push wide a bit - but having them turning slightly faster than the rears meant that it would more readily turn in in slippery conditions.
Still, I did notice that I could *never* get it back into 2WD without backing up (just a foot or so), going forward in an S pattern didn't do it. So I eventually put it in 4WD, jacked up one side, and rotated the wheels around and around... and saw them going out of 'synch'. D'oh! Got a 4.30 front diff, swapped that in, it all matches now.
Funny thing is that you could have gotten the easy-to-find Pre-Runner Tacoma locker that is 4.10. :faint:
-Charlie
Good to know. You almost never see Taco's in the PnP junkyards, though. 3rd gens are starting to show up though. You have to be fast on the draw though, but I was lucky and nabbed the 4.30 locker diff I'm using now for about $50.
but usually the diff is one of the first things to go, especially a locker. If it's been in the yard for a whole day, it's probably already gone. People know they can sell them on eBay for $$$.
I never said cheap - just easy to find! :caked:
-Charlie
